Attached Link: http://www.kerlinsoftworks.com/software/ripplerain.htm
Robo2010 you might want to take a look at Ripple Rain. It's designed for animation but I think you can probably use the generated maps for stills. I couldn't fain a way to use it with Poser 4 but with Poser 5's texture options it may work. It's included in the untitled image utilities on the download page. I get a plugin error on their page but it loaded when I clicked the messages away."Democracy is a pathetic belief in the collective wisdom of individual ignorance." - H. L. Mencken
I've used Kerlin's Ripple Rain myself -- a plugin for trueSpace. There's a feature that will create an object as well as all of the bump maps. That could be imported into Poser I think. The rain comes down in layered planes and the software also creates a horizontal plane mapped with rippled bumps. Pretty cool. Thing is you'd have to point your camera directly into the object to make it work correctly. Best Wishes, Rance
Robo2010, Ripple Rain creates nothing like the drop above. Geometry is limited to planes holding the trans and bump maps and one horizontal plane holding the bump map. It DOES time things out so that when a drop hits the horizontal the rippled bump is generated at that moment from that spot. It's pretty neat but may not be what you are looking for. Best Wishes, Rance
