It isn't difficult to apply a texture if the creator has supplied a MAT pose to do the job. Otherwise, yes, it's a pain in the arse at times. Eyelashes show as dots to indicate the material is transparent. They show correctly when rendered.
The 1st commandment is: Save. Save NOW! Save again. Save often. Save always. Save whenever you change anything. Save whenever you are abouit to change something. Save even if you only think you might have changed something. Did I mention "Save"??? (And always under a different name; you can always delete the old saves once you've got the scene working)... Cheers, Diolma
I guess the third commandment is BACKUP! And DO NOT EVER use rewriteable CDs or DVDs they are NOT secure and you will lose your data.
Hi all, I have recently bought Poser 5 and i have being so willing to learn how to use it so last night i had a go and i have a few problems: Why is it so difficult to add a texture? Why is it that when i add textures the eyelashes and eyebrows are just dots and not as they should be? thats it for now i think. I would really appreciate some help and advice. Kelly
