Tue, Feb 4, 11:08 PM CST
Subject: Poser light saves, and file size control
Sparky8 ( ) posted Fri, 17 December 2004 at 2:12 PM · edited Sun, 26 January 2025 at 6:19 PM
Much to my dismay, when I save a scene in PZ3 format, when I recall it later to work on it, all the lighting is concentrated in a single center spot...thus destroying my careful placement of the lighting.. is this normal, or am I experiencing a program problem. Second problem: My props file has grown beyond the 100 limit..I know there is a way of modifying the program to allow 1000 of them without sacrificing the thumbnails..HELP!
geep ( ) posted Fri, 17 December 2004 at 2:57 PM
Hi Sparky8,
Suggestion to remedy your 1st problem ...
Save the Lights as a Light Set in the Lights Library.
Then, if something goes haywire with the .pz3 file, you can more quickly restore (at least) the lighting.
re: 2nd problem ... do a search for Pboost <---(sp?).
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
SamTherapy ( ) posted Fri, 17 December 2004 at 3:18 PM · edited Fri, 17 December 2004 at 3:19 PM
For the second problem... If you're using P5 you need to edit LibraryPrefs.xml.
It's in Poser/Runtime/prefs.
Back it up before you start to hack away at it. Open in a text edtior such as WordPad, then search for "previewNum=".
When you found that, change the number which follows it to a higher value.
Save the file back out and you're good to go.
Message edited on: 12/17/2004 15:19
Sparky8 ( ) posted Fri, 17 December 2004 at 3:21 PM
Thanks a million! Both problems solved in minuites! WoW!
