Mon, Jan 6, 12:13 AM CST
Subject: INCOMPATIBILITY
ursule ( ) posted Tue, 21 December 2004 at 1:15 AM · edited Sun, 05 January 2025 at 11:58 PM
I've problems with VOB objects compatibility between VUE 3 and VUE 4 PRO several VOB objects can't be loaded in VUE 4 PRO ... Why ???? thank's for the response
wabe ( ) posted Tue, 21 December 2004 at 1:21 AM
The file format has changed a little - so there are incompatabilities. But on your Pro CD there should be a converter - maybe you try that out. Otherwise, ask someone with Vue 4 to open the files and save them from there again under Vue 4. Then it should work as well.
dlk30341 ( ) posted Tue, 21 December 2004 at 8:20 AM
DON'T USE the converter!!!! It messes things up bad. Not just for me but LOTS of others have complained of this also...keep in mind the converter is NOT supprted by e-on.
Don_Cook ( ) posted Tue, 21 December 2004 at 6:18 PM
I for one have never had a problem with the converter works great for me. Why would e-on have it in the program if it messes things up? If you are having a problem with the converter then report it to e-on and let them fix it.
dlk30341 ( ) posted Tue, 21 December 2004 at 6:23 PM · edited Tue, 21 December 2004 at 6:29 PM
I did report it after it had lost/damaged...MANY items...they said they don't support it & couldn't help. I attempted to use it converting V3 items to V5...thank God I had backups...it did not convert 1 single thing...just damaged all the files. I had to convert all in V4, then all OK in V5...took me 2 weeks to get all re-saved in V4. Other people have reported this same issue in other forums as well. The progran was NOT written by e-on but rather a 3rd party. It even states in the manuel they don't supprt it.
Maybe better said...use at your own risk ;)
Message edited on: 12/21/2004 18:24
Message edited on: 12/21/2004 18:26
Message edited on: 12/21/2004 18:29
Don_Cook ( ) posted Tue, 21 December 2004 at 10:26 PM
Well you can learn something new every day. I didn't know that. I just never had a problem with it so far.. Thanks
