Phillip Drawbridge
Website
Facebook
I have to admit I am not certain, just googled for historic Kentchurches, and this was the only good image I found. Didn't say where it was. Whereabouts in West Kent? I was in the Dartford area.
The greatest part of wisdom is learning to develop the ineffable genius of extracting the "neither here nor there" out of any situation...."
Are you uv mapping the church so that each surface is separate? I have found that Bryce likes uv mapped models, especially when you use PROCEDURAL textures. I do not know if any others have experienced this, but when trying to get PROCEDURAL textures to work usually they refuse to tile properly on one or two sides. If that happens to you, you can open your model in uv mapper then apply box mapping and save it out. Now, when it opens in Bryce and you use PROCEDURAL textures with PARAMETRIC mapping, the tiling will work on all the sides properly.
Message edited on: 12/21/2004 18:43
nice pic only grumbles is that for a beggar his hair is too neat try some dread locks
for
some free stuff i made
and
for almost daily fotos
Attached Link: http://www.davegh.com/blade/davegh.htm
pog - I believe this is the site you are referring to?Thanks everyone. I will try out those 2 mats dvd master. GG...As per my usual habit the church is all built from bryce primitives, well mostly all. I did find the window somewhere. The door arch is actually a flat square using one of the textures from the site jaymonjay mentioned and a trans I made from it. Think I will have to have another go at that church. It just didn't go as well as the Lych gate. No post work yet..can sort hair out later.
Pakled: "He goes down to the bog to warm his feet..." Chohole's pic made me think of Aqualung, too. He's not really an object of pity, though. Something to do with his "eyeing little girls with bad intent." probably. :^)
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=840827
And for better or for worse its now in the gallery...(minus the brown snow). I am afraid Pakled and Tjohn's comments are above my head..what am I missing?The greatest part of wisdom is learning to develop the ineffable genius of extracting the "neither here nor there" out of any situation...."
Attached Link: http://www.marcogiunco.com/dischi/000757.jpg
That turned out rather well, Chohole, my compliments. The begger in your image reminded them of Jethro Tull's song Aqualung and they're reciting the lyrics to it. Aqualung my friend --Dont start away uneasy You poor old sod, you see, its only meSitting on a park bench --
Eyeing little girls with bad intent.
Snot running down his nose --
Greasy fingers smearing shabby clothes.
Drying in the cold sun --
Watching as the frilly panties run.
Feeling like a dead duck --
Spitting out pieces of his broken luck.
Sun streaking cold --
An old man wandering lonely.
Taking time
The only way he knows.
Leg hurting bad,
As he bends to pick a dog-end --
And warms his feet.
Feeling alone --
The armys up the rode
Salvation la mode and
A cup of tea.
You poor old sod, you see, its only me.
Do you still remember
Decembers foggy freeze --
When the ice that
Clings on to your beard is
Screaming agony.
And you snatch your rattling last breaths
With deep-sea-diver sounds,
And the flowers bloom like
Madness in the spring.
Message edited on: 12/22/2004 15:37
"frilly panties" I think should be "pretty Peggys" :)
