Thu, Feb 13, 3:28 AM CST
Subject: having problem installing upgrade of poser5
maxapple ( ) posted Sat, 25 December 2004 at 9:39 AM ยท edited Sun, 09 February 2025 at 6:15 PM
I 'v just got the upgrade version of poser 5 version 5.0.3. how ever i can't enter the serial numbers as they were issued. The dash after the numbers can not be reproduced by my computer. The dash is up high not like example; 6_, or 6- its 6 the dash is up at the top.
thanks and happy holidays.
nickedshield ( ) posted Sat, 25 December 2004 at 9:42 AM
There was a thread on this awhile back, let's see if I remember- try changing the _ to zero.
chriscox ( ) posted Sat, 25 December 2004 at 2:04 PM
First, you should get the latest patch from Curious Labs. The latest patch is 5.0.4.325. If you're using Windows and still having a problem entering dashes from you keyboard and using Zeros didn't work you might want to try enter the hyphen using an ALT code. To do this Press the ALT key, then while keeping the ALT key pressed type 0045.
Chris Cox
xantor ( ) posted Sat, 25 December 2004 at 9:53 PM
You should download service release 4.1 from www.curiouslabs.com.
Irish ( ) posted Sun, 26 December 2004 at 8:07 AM
I had the exact same problem and yes, download and install the latest update then enter your serial number using zero where the upper dashes are - it should then work for you. :)
