Waves are bloody hard to do. I've tried and failed many times. I look at Hobbits waves and think that Photoshop may be the best way. but then that relies on traditional art talent, which I am lacking. I like the slight spiral effect you've got going on the tower. Very cool. Was that by accident or design?
Phillip Drawbridge
Website
Facebook
This is turning out fantastic, I have to agree about the grass. Water? When working with water, post gives me the most control. The "pureanodyne" brushes for photoshop are the best I've seen. Also working with very large files helps with control.(memory intensive though) If you work in PS & want to try the brushes let me know.
___
Ockham's razor- It's that simple
Thanks, DVD. It's the photo-sky (Mayang's) + Brycean sky method. I merely took 5 2d squares, mapped the photo-sky to them, and positioned them in a huge, distant box formation around the scene. This way, the water will pick up skies from each side and the back and top of the scene, as well as the 2D square stretched out in the camera's viewpoint... I'd normally use a half-sphere, but there were few artifacts so I just left it that way... So you set the 2d sky photo to Blend Transparency, and the Brycean sky comes through a bit since it's infinitely behind everything. Turn up the bump to 500 on the 2d photo-sky, and boom, you're in...
