Mon, Feb 10, 12:01 AM CST
Subject: Scaling Figure Down
arrow1 ( ) posted Mon, 27 December 2004 at 3:00 PM · edited Sun, 09 February 2025 at 11:23 PM
Is there a script or some means of scaling a Poser Figure including all clothes and props down to say twenty percent?.I want to then save it a a PZ3 for importing into Vue5!I am finding at the moment that after scaling the figure I have to also do the clothes and props even after conforming and parenting! arrow1
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
lesbentley ( ) posted Mon, 27 December 2004 at 3:54 PM
Load a Poser square prop (preferably as the first object in the document). Use 'Figure' > 'Set Figure Parent', to parent all figures to the square. Use 'Object' > Change Parent' to parent all props to the square. Scale the square. Use 'Object' > 'Properties' > 'Visible', to hide the square.
arrow1 ( ) posted Mon, 27 December 2004 at 4:30 PM
Many Thanks.I will give it a go! arrow1
arrow1 ( ) posted Mon, 27 December 2004 at 4:57 PM
lesbenley,Do I load the square prop before I load any figures etc, as soon as I open Poser? Cheers arrow1
nickedshield ( ) posted Mon, 27 December 2004 at 7:07 PM
Oh, thanks for that tip:)))) It worked extremely well on a cabin that's a PITA to manually scale.
arrow1 ( ) posted Mon, 27 December 2004 at 11:58 PM
Thanks again Les! It worked fine.Some objects such as parented hair and jewellery don't need parenting to the square! arrow1
Kalypso ( ) posted Tue, 28 December 2004 at 2:46 AM
Site Admin Online Now!
Also another quick way to parent is to just open the hierarchy window and drag all your figures onto the square prop. Any props parented to the figures will not need to be reparented to the square as mentioned above. I usually do this even in Poser to be able to manipulate a scene after I've applied the lighting and don't want to ruin the angle or if I want to z-toon the entire scene.
jehllm ( ) posted Tue, 28 December 2004 at 6:45 AM
that is a very helpful tip - thank you!
lesbentley ( ) posted Wed, 29 December 2004 at 4:21 PM
Re post #6: "Some objects such as parented hair and jewellery don't need parenting to the square!" Yes, in most cases it should be sufficent to parent the base actor/prop in each parenting chain to the square.
