Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 06 11:30 am)
well having them able to 'untie' would be impossible in poser as far as I can wrap my brain around that. You may need to have two different versions.
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
One with posable strings that you could tie and untie would be theoretically possible, but would be incredible complex and might have a rather large polygon count because of all the sections the strings would have to have to make it posable. Also it would be murder to pose it. I'm fairly certain nobody has ever made one, and if one were available, as hard as it would be to make, I'd be surprised if it was offered free. IMO you'd be better off to have, as odeathoflife suggested, two versions (one tied, and the other untied)
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
ii think shadownet has some version for v3 of a v2 daz bikini tht can come off and undo etc love esther
I aim to update it about once a month. Oh, and it's free!
Judy has a bikini set as well as underwear in conforming you could try to export those and select weld body parts i the export dialog then iimport them back in and try them in the cloth room?
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
Attached Link: http://www.philc.net
Philc is getting ready to release his new Clothing Creator plugin that will enable you to actually make the bikini from a psd file in Photoshop. I have been beta testing it and it is quite exciting. It is due to be released Jan1. you might check it out. cheerio lululeeAttached Link: http://www.poserfashion.net/downloadp5.htm
Poserfashion has a very good tutorial on editing the constrained group so it does not fall dowm. It is quite easy.At www.planit3d.com you will find what you are looking for. Go to freestuff dynamic clothing and dl the underwear package for V3. Then take a mesh editor and cut it up in the front or in the back.
Oh, its also in the freestuff here - search for svdl
Message edited on: 12/29/2004 11:35
Message edited on: 12/29/2004 11:40
hi i trying to find some dynamic clothing for P5 need a bikini ...top has upper and lower stings untiable ...and thong bottom also need 2 bras, one with clasps in front, other in back anyone know where i can find for free? or way to make them? thanks
