Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2024 Nov 27 6:56 pm)
Technical notes: The ruined house is highly detailed and textured, and can take close up renders. The ladder and drum can be moved, once again with the EAP system.
Your specialist military, sci-fi, historical and real world site.
Technical notes: The gun can turn and elevate, the doors on the ammo can open and close, and the drum can be moved. The roof can also be made invisible for easier setting up of figures. The model includes many camera files using the dolly camera, and there is a small tutorial included with the model to show you some easier ways of using a model of this size.
Technical notes: Detailed textures means you can zoom in and render close up shots, as the model uses a unique texturing system that allows high detail with low texture use. The method is similar to tiling, but allows variation in the tiling to prevent the square effect that tiling sometimes produces. This model is massive, but uses the same amount of textures as a high-res Vicky 3 with a set of clothes would use. I will post some close up shots to show the texture detail tomorrow.
Attached Link: http://www.vanishingpoint.biz/productdetail.asp?productID=55
Ok, the model is available here.We have submitted to rendo and PoserPros, but I don't know how long that will take to clear. Is the price OK?
Technical notes: Model includes two landing craft, both with ERC controls for the ramp cabling, working doors, steering wheels and hatches. The waves are pre-animated using a supplied pose file if you are an animator. The beach obstacles are body parts, and can be made invisible if you don't want them.
EAP system: The entire model is one figure. This means that the landing craft are part of the model, and you move them using the dials. You can move them left and right, forwards and back, and you can turn them. You cannot move them into the sky (they aren't airborne ships, after all) and you can't move them off the map. If you don't want them, just make them invisible.
