Sun, Feb 16, 11:20 PM CST
Subject: Import Problem
deevee ( ) posted Tue, 04 January 2005 at 2:18 PM · edited Sat, 21 December 2024 at 9:23 AM
I have Vue 4.22, Vue 5 and Vue Pro 4 Demo. I tried to import an object using all three, and only Pro Demo imported it corectly. Is there a reason for this? has anyone else who has all three programs installed experienced this situation? If you have, and have overcome it, would you be willing to pass this information on.
Thanks,
deevee(Joe)
Pen_Is_Envy ( ) posted Tue, 04 January 2005 at 3:14 PM
Joe, I had had this problem with my Vue 4 Pro (don't have the others), and as it turned out the issue was my not having the most recent updates for the software. Once that was done, everything was fine. But seeing as the Pro Demo was the one that worked correctly for you, this probably doesn't help you much. :(
wabe ( ) posted Tue, 04 January 2005 at 3:32 PM
Joe, could you give a little more information what sort of model (file format) you have used? I think Vue 4 Pro has the most options for import, more than the others. As far as i remember. So maybe this is the problem, that you use a file format that only 4 Pro is able to deal with.
deevee ( ) posted Tue, 04 January 2005 at 3:38 PM · edited Tue, 04 January 2005 at 3:38 PM
Thanks for the replies, they were 3DS Max files.
Message edited on: 01/04/2005 15:38
wabe ( ) posted Wed, 05 January 2005 at 4:13 AM
you mean .3ds-files or .max ones? The native 3D Studio Max files can't be opened. You need specific convertions on the max side. You can do a little search here in the forum and you will find some discussions about that issue.
deevee ( ) posted Wed, 05 January 2005 at 6:50 AM
I ment .3DS files sorry forpassing on the wrong information. Thanks for the information.
wabe ( ) posted Wed, 05 January 2005 at 9:32 AM
Well then it is a little weird - a little. 3DS is not as normed as it should be. So there are different variations around. Some Vue can read better, others it cant. I normally get a warnign when i use 3DS from Cinema4D, even with a very late version 8. Especially the textures are identified as a problem. Maybe you can report that issue to E-on, they are surely interested especially when different Vue versions show different ways to deal with it. Sorry that i cant help more.
