Wed, Feb 26, 3:11 AM CST
Forum Moderators: RedPhantom
Subject: Remove runtime folder.
elindsa ( ) posted Fri, 07 January 2005 at 9:54 AM · edited Tue, 25 February 2025 at 9:59 PM
Hi, I would like to ask if it is possible to copy the runtime folder without loosing the stuff I have inside, and how to do that? I have installed Poser 5 on D instead of C and want my things to follow:-))). Hugs Elin.
Bobbie_Boucher ( ) posted Fri, 07 January 2005 at 10:19 AM
You should be able just to copy the Runtime folder over. You might want to at least run CorrectReference to be sure everything works properly. You don't really need us to tell you how to copy a folder? When in doubt, use a good file manager program. I'm partial to Powerdesk Pro 6 myself.
rreynolds ( ) posted Fri, 07 January 2005 at 10:21 AM
Just copying the folder over should do the trick. Some freebies have a hard coded location that specify a drive/directory instead of pointing to the Runtime folder. CorrectReference (a freebie utility) can be run to help sort out those problems.
elindsa ( ) posted Fri, 07 January 2005 at 10:45 AM
Thank you both. I will try that and close my eyes and cross my fingers.-))). Hugs Elin.
Philywebrider ( ) posted Fri, 07 January 2005 at 1:36 PM
I tried copying the runtime, and I got this message. What do I do now? Windows XP
SWAMP ( ) posted Fri, 07 January 2005 at 3:04 PM
Hit "yes to all". "Thumbs.db" is just the thumbnail cache...it will be created again....you don't need it.
Philywebrider ( ) posted Fri, 07 January 2005 at 3:30 PM
Many thanks.
Bobbie_Boucher ( ) posted Fri, 07 January 2005 at 3:48 PM
I always delete that darned Thumbs.db file.
SWAMP ( ) posted Fri, 07 January 2005 at 3:59 PM · edited Fri, 07 January 2005 at 4:00 PM
Actually in your folder options you can check an option to not create them in the first place. Then do a search for "Thumbs.db" and delete all found on your system.
Message edited on: 01/07/2005 16:00
Philywebrider ( ) posted Fri, 07 January 2005 at 4:53 PM
How is this a benefit?
SWAMP ( ) posted Fri, 07 January 2005 at 6:32 PM
Well it's not really a benefit for people that have a lot of images. I only mentioned it because some don't like all those "Thumbs.db" if they move files and folders around a lot (if you notice I don't have it checked as I prefer to use it). What it does is cache the images of your thumbnails so they display faster. Without it you'll still see your thumbnails it just takes longer for them to load/display.
Bobbie_Boucher ( ) posted Fri, 07 January 2005 at 7:48 PM · edited Fri, 07 January 2005 at 7:48 PM
I've noticed those things even come with items I've just installed, or in zip files of stuff I've downloaded or bought. Hey, in that case, the little bugger(s) come from someone else's computer. I don't need someone else's helpers.
I use Thumbsplus for my thumbnails, so I don't need that extra stuff.
Message edited on: 01/07/2005 19:48
dlk30341 ( ) posted Fri, 07 January 2005 at 8:19 PM · edited Fri, 07 January 2005 at 8:20 PM
I delete all the thumbs.db I find in any zip before extracting. AS well as any .jpgs that have an ad pic in them...HD space is precious.
Message edited on: 01/07/2005 20:20
