Mon, Jan 13, 7:43 AM CST
Subject: Image and a question
drmca ( ) posted Sat, 08 January 2005 at 5:49 PM · edited Mon, 13 January 2025 at 7:31 AM
I have a question, regarding this image. Anyone have any ideas on how to create more realistic foaming water (from the propeller), without using postwork, I prefer to not use postwork. Thanks Dennis
Message edited on: 01/08/2005 17:53
thomllama ( ) posted Sat, 08 January 2005 at 10:03 PM
just a guess.. but couldn't you use the fountain? have it shoot white foamy balls? first thing t ocome to my mind
Hexagon, Carrara, Sculptris, and recently Sketchup.
thomllama ( ) posted Sat, 08 January 2005 at 10:10 PM · edited Sat, 08 January 2005 at 10:11 PM
sorry wrong program.. I was thinking I was in the Carrara forum look at to many places :)
other thought.. use the terrain? make a very small hill... add small bumps... clip edges... add a foamy texture.. once again.. just a guess actually what you have isn't bad... reshape it... make it a bit more transparent..?
Message edited on: 01/08/2005 22:11
drmca ( ) posted Sat, 08 January 2005 at 10:42 PM
Thanks Thomallama, I'll go back and play with it.
wabe ( ) posted Sun, 09 January 2005 at 4:35 AM
You can use a terrain (symmetric for example) with a suiting material. Maybe you go to www.guitta.net there is a tutorial for foam i think. I hope that will help.
FearaJinx ( ) posted Sun, 09 January 2005 at 9:53 AM
You could try little tiny bubbles with transparent stuff.
ggrace ( ) posted Sun, 09 January 2005 at 6:44 PM
Just for fun create a gray scale image of a spiral and load it in the terrain editor and tweak the procedural settings for noise and then txture it with bubles and foam,,,it might work and you will learn a lot even if dosen't.
drmca ( ) posted Mon, 10 January 2005 at 9:33 PM
Thanks all, I've tried all of the above with mixed results. At one time I did have one that looked quite good butt, the render time was ridiculous. I will play around with it again.
HellBorn ( ) posted Tue, 11 January 2005 at 5:15 AM
Well in stead of post work you could do some prework ;) Use something like Particle Illusion or a paint app to paint a lot of small bubbles as well as an alpha mapp for them and then render them together or if your using pro create a Phyton script that generates the bubbles.
drmca ( ) posted Tue, 11 January 2005 at 7:26 PM
LOL, though actually prework does sound beter ;0) Thanks HellBorn
