Are you new to the program? Just curious. When you click the button "Source File" a windows dialog box should pop up (mine pops up to the "My Documents" folder). If nothing is happening, you may want to reinstall, or redownload and reinstall. If that doesn't work, you may want to contact the program creator.
Yes, I'm new to the program. When I click "Source File" a windows dialog box does pop up. Then, I select a cr2 file I have created, I click Open, then nothing happens. I contacted DAZ's Technical Support. They just reminded me the procedure. It looks like it isn't a common problem. I was hopping someone had met the same problem and could tell me what to do.
This is assuming you're using the same version as me, 1.5 After loading your CR2, there should be something in the Log box (upper left pane) that says: "Retrieving [file path of your CR2]; X lines queued; Done" then "Sorting... Done" On the right, choose the figure the morphs were made for (Victoria3, etc.) and there should be additional lines in the log. Are you saying you're getting absolutely nothing happening in the log area?
Absolutely nothing. When I open IPB I have this in the log area : "Reading: D:Program FilesDAZInjection Pose BuilderOptionsStartup.cfg Done" When I try to open a cr2 file, nothing changes. When I click Victoria 3 in the Link Libraries, I get: "Retrieving: D:Program FilesDAZInjection Pose BuilderlibsVictoria3.ill 1229 lines queued Parsing... Done" I don't know what that means but I still can't process.
This is totally confusing. Your last message just indicated the program is working just fine. Yet your first message implied it was not working. Injection Pose Builder is a program that allows you to share characters you've created. Here's the general procedure. We'll use Vicky 3 for an example. 1.) Create your character, and save her to the Character Library. 2.) Run Injection Pose Builder, and load your custom character. Wait for the message that says "Done." 3.) Since your character is based on Victoria 3, you want to choose Victoria3 from the Link Libraries. 4.) Under Options, you'll probably want to select INJ & REM Poses. This allows people to create the character, and then put it back to normal. 5.) Click the Process Options button, and wait for the program to finish. You'll see all the words in the Output Source box. 6.) When you're done, click the Save As button, and save the resulting files into your Pose Library.
That's right Evilded777. I red that in a tutorial on DAZ's. I thought this was optional to reduce processing time. But I don't know where to find these REM pose IPB Prep. Perhaps I should reinstall V3. To answer Bobbie, my problem is on step 5 of your procedure. When I click the Process Option button I am asked to load a source file, while I have already done it on step 2. I'll check for those REM pose.
I promise to check when I get home... I thought IPB loaded some of those Poses when I installed it, but I could be wrong. I know I had HUGE troubles building some Poses for David until I 1) updated IPB and 2) created an IPB Prep Pose for him. I think I had a similar problem tp the one you are suggesting Simbad6, but I do not remember exactly. And i would say that the IPB Prep pose is NOT optional. Reduce processing time is not the word. SLASH Processing time is more like it.
Hi, I've not yet installed the latest update for the Young Teens but with my last installation, the prep poses were not installed into Poser's runtime. If you open explorer, go to the program directory and find the IPB folder, you will find a runtime directory somewhere in there with the various poses. Philebus
I finally found the IPB prep. They were located in the Support Files folder of IPB. They don't install automatically into PoserRuntime. You have to move them manually to RuntimeLibrariesDAZ and RuntimeLibrariesPose. I applied it to a V3 character I created. I suppose it does remove the Morph Delta's although I don't know how to check it. But I'm not sure it's the point because when I try to load it in IPB, I still get the "Please load a source file to continue" message when I hit Process Options.
Hi all ! I am getting crazy with this IPB 1.5. When I click on Source File to load a cr2 file, nothing happens. No new message appears in the "Log" window. It looks like nothing has been loaded. Actually, if I click the Process Option button next, I get the message : "Please load a source file to continue". Has anyone experienced this problem ?
