Sat, Jan 11, 12:09 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
Subject: need to bend knees of model doing shoulder stand
griffen ( ) posted Mon, 10 January 2005 at 5:10 PM ยท edited Fri, 10 January 2025 at 9:49 PM
Hi there,
I'm a newbie to Poser, and I'm working on an exercise manual. I want to illustrate a sequence of related body positions. I got the first one (attached) but now I want to bend the model's knees so that her legs form a diamond shape (knees apart, soles of feet together). I figure this must be possible, but none of the leg body parts seem to get me where I want to go.
Suggestions?
Thanks so much,
griffen
SamTherapy ( ) posted Mon, 10 January 2005 at 5:15 PM
Switch off IK. They'll bend then.
bnetta ( ) posted Mon, 10 January 2005 at 5:59 PM
ok i have been using for along time and don't know where to find that to turn it off...(unless there's one in the pose folder).lol and this is a newbie so maybe you could help us both... i'm afraid i've had the same problem in the past but, never took the time to find the answer and just changed to a different pose...lol i know, iknow, bad me..lol netta
www.oodlesdoodles.com
griffen ( ) posted Mon, 10 January 2005 at 6:07 PM
First, thank you to samtherapy. Bnetta, if you go to the Figure pull down menu while the appropriate body part is selected (like a thigh, if you want to affect the leg's IK attributes) then you'll be able to select Use Inverse Kinematics. griffen
SamTherapy ( ) posted Mon, 10 January 2005 at 6:18 PM
You're welcome. You don't need to select the appropriate body part, BTW. Just the model itself. IK can be useful some of the time but mostly it's a huge pain in the arse.
dbowers22 ( ) posted Mon, 10 January 2005 at 7:42 PM
I put on character on a bicycle and it worked great for getting the feet positioned perfectly on the peddles. Bout the only time I have actually found IK to be a help rather than a hinderance.
xantor ( ) posted Mon, 10 January 2005 at 8:30 PM
Ik is very good for animation and some posing.
griffen ( ) posted Mon, 10 January 2005 at 10:21 PM
hauksdottir ( ) posted Tue, 11 January 2005 at 8:49 PM
You might also want to check out Karen1573's yoga pose set in the MarketPlace. They may be different or more extreme than you are using for this exercise program, but they might also be good starting points. Worth a look. Carolly
griffen ( ) posted Wed, 12 January 2005 at 1:42 AM
Hi Carolly, Thanks for the heads up. I checked 'em out, and they're quite nice, but I seem to be managing ok by using the existing poses already included with the program. That IK tip really changed everything. I did like the clasped hands especially on some of Karen's poses, although they weren't especially applicable for Pilates movements, which is what I'm doing. griffen
narcissus ( ) posted Fri, 14 January 2005 at 7:13 AM
Attached Link: http://www.renderosity.com/homepage.ez?Who=narcissus&ViewArticle=7709
If you want I have a small,very small tutorial on posing... pitklad
