Sun, Nov 24, 1:52 AM CST
Subject: Where is Twist Hairs Tool? -Poser 5
Jim564 ( ) posted Tue, 11 January 2005 at 6:14 PM ยท edited Sat, 23 November 2024 at 11:30 PM
Hi-
I've just begun working my way through the tutorial "Growing Hair," in Poser 5's manual. I've pretty much muddled through, so far. But I can't find the TWIST HAIRS tool referred to on page 67 step 19 of GROWING HAIR.
I'm in the Hair Room. Could someone please direct me to the Twist Hairs Tool? :-) The instruction merely directs to "Select the TWIST HAIRS tool and drag your mouse left or right."
Thanx - Jim
ArtyMotion ( ) posted Tue, 11 January 2005 at 6:44 PM
In Section 3 of the hair room, there is a button that says "Style Hairs." When you click that button, the Hair Style Tool palette pops up. At first, only one button is enabled ... that is the tool that you select hairs to work on. After that, the remaining tools are active. They are, in top row, Translate (Move), Curl, and Scale on the top row; and Deselect, Translate Hairs In and Out, and Twist on the bottom row.
Jim564 ( ) posted Wed, 12 January 2005 at 4:57 PM
ArtyMotion-
Thank you very much. You advice was flawless.
I'm pretty sure I wouldn't have discovered that on my own. Even though the manual seems to think so. :-)
Thank you again - Jim.
