Tue, Feb 11, 6:08 AM CST
Subject: Poser 5 Texture Help
chibi_lenne ( ) posted Fri, 14 January 2005 at 10:09 PM · edited Tue, 11 February 2025 at 6:01 AM
I feel like such a newbie -_- gee maybe because I am? Anyway, I'm stuck, I want to use Uthena's medieval style dress, and I downloaded a texture here at Renderosity for it...now I'm having one problem...I can't figure out how to apply the texture to the dress...please help!!
Alpha9992004 ( ) posted Fri, 14 January 2005 at 10:15 PM
  1. Start a blank scene in Poser Load your figure(s) & pose them. 2. Switch to the material room. (Ctrl + U is the hot key to open up the Materials Room) 3. Pick the eye dropper tool. 4. Open the Library > Materials & choose one you want to apply the map to. 5. Click the plug (Root node) for diffuse color. 6. Select "New Node" > 2D Texture > Image Map (You can also choose the Material from at the top of the Shader Window) (The Triangle by Node Options) 7. On the Image Map Window, Click on "None" by image source. 8. Click "Browse". 9. Find your texture & select it. 10. Click "OK" on the Choose Texture box. 11. Be sure the diffuse color is solid white. 12. The diffuse value should be 1.000000 13. The rest of the colors should be solid black. 14. The other parameters should be 0.00 Tip: You can copy and paste nodes with a right click of the mouse. Tip: If you use the P4 Renderer be sure to put a check on "Use Texture Maps" FAQ: I can't see my texture until I render the scene. You can only see the textures in "Texture Shaded " view. Press Ctrl + 9 for this mode. The colors are off in my texture. The texture colors are effected by the color of the lights in your scene. Use white lights for better texture colors. Object colors effect the texture color. Be sure the diffuse color is solid white.
chibi_lenne ( ) posted Fri, 14 January 2005 at 10:54 PM
No, still no help, I still can't get the texture onto the dress sighs
Bobbie_Boucher ( ) posted Fri, 14 January 2005 at 11:47 PM · edited Fri, 14 January 2005 at 11:50 PM
Attached Link: dress
This may sound inredibly obvious. Usually when you get a texture, there is a MAT Pose file in the Pose Library. Use that. I did some looking, and think I found the dress. It clearly states there are MAT Pose files.
Message edited on: 01/14/2005 23:50
Irish ( ) posted Sat, 15 January 2005 at 12:39 AM
Did you download the actual dress? It is not in Free Stuff anymore, just textures for the Uthena Dress by Wynter. :)
chibi_lenne ( ) posted Sat, 15 January 2005 at 12:56 AM
Yes, I do have the actual dress ^_^; I made sure to go an find a download of it, though I may have to find another download for it, because there was no MAT pose files for it.
Alpha9992004 ( ) posted Sat, 15 January 2005 at 1:04 PM
That's all know Lenne. That should have worked. TRY IT AGAIN!!! lol! I thought that was laid out really good for you........
queri ( ) posted Sun, 16 January 2005 at 12:27 AM
Is the actual dress a character? Just making sure. Emily
