Fri, Nov 29, 11:46 PM CST
Subject: Removing Older V3s from Figure Library
KyReb ( ) posted Sat, 15 January 2005 at 1:42 AM ยท edited Mon, 25 November 2024 at 1:21 PM
My figure Library has several V3s. Victoria 3 Victoria 3 SR1 Victoria 3 SR2 Victoria 3 MM Can I go ahead and hit the Minus on some of these without causing any damage??
Bobbie_Boucher ( ) posted Sat, 15 January 2005 at 1:56 AM
Attached Link: DAZ3D
I don't know what Victoria 3 MM is. The other ones are actually old versions of Vicky 3. The newest one is Vicky 3 SAE. You can get her for free at DAZ3D now.
SWAMP ( ) posted Sat, 15 January 2005 at 2:11 AM
Well if Vic 3 SR2 is your most current Vic you can delete the Vic 3 and Vic SR1. The Victoria 3 MM is the Cr2 that came with the "head sculpt pack" for those special inj/rem to work properly...you DON'T want to delete that one. SWAMP
zvzulndr ( ) posted Sat, 15 January 2005 at 7:19 AM
On the same note, how do you handle crosstalk with the V3 SAE? every thing I have tried has failed: I either lose the morphs or don't get them. Yes I have read the FAQs (confusing and I am very computer literate). This crosstalk problem is making Poser much less enjoyable. Is there a NULL CR for V3 SAE or M3?
SWAMP ( ) posted Sat, 15 January 2005 at 8:58 AM ยท edited Sat, 15 January 2005 at 9:01 AM
Attached Link: http://www.nerd3d.com/catalog/index.php?cPath=1&sort=2a&page=2
Nerd's crosstalk fixer Cr2..... It comes with a little mini-tut on it's use.
Message edited on: 01/15/2005 09:01
RHaseltine ( ) posted Sat, 15 January 2005 at 9:16 AM
If you have the International Beauties set you need the update for the Head Sculpture pack that will give you a Victoria 3 SR2 MM file to replace your Victoria 3 MM: there isn't an MM version of the new Victoria 3 SAE yet.
SWAMP ( ) posted Sat, 15 January 2005 at 7:47 PM
Or you can do what I did... Just transfer the head morphs from the MM cr2 to the standard Vic cr2 with MorphManager and be done with it (took all of 20 sec).
Strixowl ( ) posted Sat, 15 January 2005 at 8:45 PM
Oh great. I guess I missed something. I've got Victoria 3,Victoria 3 SR1,Victoria 3 SR2,even Victoria 3 MM, but just now heard of SAE. What is Victoria 3 SAE? Is it worth down loading? What's differant? It sounds like it has some problems (above), does it? Where at DAZ is it? Thanks in advance for your response(s)
Bobbie_Boucher ( ) posted Sat, 15 January 2005 at 9:10 PM
Victoria 3 SAE is the latest version of Victoria 3. Everyone gets Vicky 3 for free now. Yes, it's worth downloading.(As stated above), you want to get her, and delete your Vicky SR1 & SR2.
RHaseltine ( ) posted Sun, 16 January 2005 at 9:00 AM
V3 SAE has the expression morphs in the figure file, so you don't have to make a trip to the pose library (and there are some extras compared to the original), it has scalable hands as in Aiko 3 and the elemental and it fixes a misspelled channel introduced with SR2 (HdPhilipino). There is an update on the DAZ Updates page, in the Support menu in the page header.
Strixowl ( ) posted Sun, 16 January 2005 at 12:26 PM
Big thank You, Bobbie_Boucher & RHaseltine :-)
Bobbie_Boucher ( ) posted Sun, 16 January 2005 at 9:40 PM
Anytime.
