Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Yes. It works very well usually. I can't post a file that large, though. I've got a nice little 'low end' video editor called PowerDirector that I use to make mpeg2 files usually. I'll see if it'll let me make some kinda small file format and check back if I can generate an uploadable video of a walk cycle.
...there are about 25 'walk types' when using Nerds walk designer. I think Poser comes with a good 15'ish or so by itself if I remember right. Not sure. There are also six "tweaks": Head Bounce, Arm Swing, Arm Out, Hip Swing, Leg Lift, and Stride. I should have mentioned too that you can choose any combination of any walk types you like, i.e. 25% P4 run, 42% strut using negative percentages if ya like, and then tack on whatever combination of tweaks you choose.
Attached Link: http://homepage.mac.com/prezdavidl_macnj/
hi- I made a 3minute animation last Spring using Poser 5 and Carrara 3. It involved a man and his cat . Check out a small version at http://homepage.mac.com/prezdavidl_macnj/ Click on "One Day in the Park"This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
I have seen many still Poser characters imported and rendered in C4. Has anyone imported an animated character from Poser - such as one with a walk cycle attached? I would be curious to see an example of this if anyone has done so. Thanks.
