Mon, Feb 10, 10:16 AM CST
Subject: Big Bird (Front Line Support Plane) 02
darkness_02 ( ) posted Wed, 19 January 2005 at 10:04 AM · edited Sun, 19 January 2025 at 10:12 AM
Well people I've been working on this one 4 a little bit longer... last night I was going to put it into the done area and more on... but after all ur comments I've going to stay with it a little longer and see wot I can do with it... PS comments plz thanks from darkness
You imagination is your only limitation.
Check out Dark Design for freebies for your own artwork.
Sitemail Dark Design
alexsm ( ) posted Wed, 19 January 2005 at 10:51 AM
Whay you do the big flash on the top imege ? this teke half on image ...
draculaz ( ) posted Wed, 19 January 2005 at 11:04 AM
the plane's okay, although I'd work a bit more on the wings (try metaballs), look up some reference pictures on airplane wings. i like the amount of detail on the guns and so on. the walker i can't see very well because of the blast. drac
TobinLam ( ) posted Wed, 19 January 2005 at 11:57 AM
I know its your plane, but the inlets should be a lot smaller. If you look at the size of intakes on fighter jets compared to the size of the exhaust you will find the area of the inlet seems to be just a little bit larger than the area of the exhaust. The side laser pods should blend into the body as well. I like how you got away with not modelling the body of the walker and replacing it with an explosion.
ysvry ( ) posted Wed, 19 January 2005 at 5:23 PM
i liked the guns better at the end off the wings that looked more balanced
for some free stuff i made
and for almost daily fotos
