Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 11 3:01 am)
....hey Mason, didn't realize you were the author of Morph Manager (I use it all the time!; I know, I'm stupid). Pay no attention to that long and arduous thread about your posting. Your work is excellent. Thanks for posting this, although I can't seem to get it at all..........I'll keep trying....... Krel
I am glad to see your work is back up. Although it is something I personally probably won't have a use for it will be appreciated by many... As the show once said 'Different Strokes'. :)
Senior MarketPlace Tester
If anyone sees a mind wandering aimlessly around..... It is mine.
I want it back.
joeyb - I believe the eve figure seperates the chest into two 3 regions making left and right regions part of the collar bones. It still uses the original p4 mesh. This mesh is the standard p4 mesh only it has twice the polygons around the bs. Kind of like adding a higher poly count face to p4 fem which is what Vickie is. This way the bs can be modelled better without huge jagged polygons. Use it only if you need higher detail in the fem chest area.
![file_140561.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_140561.jpg)
This file is a cr2 with the new chest info embedded as a new grouping. It overrides the data in your obj and does not require an obj install. It will not erase your obj. Instructions come with on how to move this to another figure. Only attempt this if you are an advanced user. I added about 10 MTs with it. If used, older p4 fem chest MTs will not work. The b****s have been tesselated and the n*****s are cleaned up with higher detail added. Will work with any figure that currently uses the p4 fem chest including eve hybrids. Again, this is at geocities so you'll have to right click and do a save as or save target as.
