Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 4:22 pm)
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2076958&Form.sess_id=28016685&Form.sess_key
yep, what Maxx said, but you can get various grades of edge just with the map setting alone. I've been working to exhaustion on controlling qualities of shadow maps. For instance, attached link. ::::: Opera :::::My best advise to date... If you want eye reflections but not the hard shadows... Raytrace infinite light; shadow=0.0001 default on the rest (rayTrace spot same) Put one shadowmap spot in front (3-4 pu, away); shadow=1.000 Map+1024.00 Control it with bias = 0.550...lower/darker...guessing on distance) And/or.. Angle start=50.00 Angle end=160.00 Dist Start=1.00 Dist End=4.00 +/-...increase will send shadowzone further If you don't care about reflections (eyes have it only), turn off RayTrace in renderoptions. Saves you some loadtime
now this is interesting. I've been wanting to ask about eye relections. Richardson, you are so advanced that your shorthand usually goes over my head. please unpack if you would. are you saying (for a two-light scene) put one shadowmap spot in front of the models face aimed at the eyes with the settings shadow=1.000 Map+1024.00 bias = 0.550...lower/darker...guessing on distance) Angle start=50.00 Angle end=160.00 Dist Start=1.00 Dist End=4.00 +/-... AND then put one Raytrace infinite in the scene, shadow 0.001? [[what do you mean "default on the rest (rayTrace spot same)"?]] Thanks for your help, i really want to understand. ::::: Opera ::::
A one finger typer with no time...
Yes+ No...For HIS scene, I meant to change his primary RTrace to a dead shadow (0.0001)if he wants reflects.
You don't have to use RayTrace shadows...they suck! But you can use Reflect and Refract functions without the shadows... (0.0001) on shadow defangs it.
I should add...if you don't want RayTrace anything, then covert it or pitch it or turn it off.
The nice blurrable shadows you get with shadowmap spots. See above my previos post^
What RayTrace does well...Use a RayTrace (full power) to penetrate all the transmaps in a portrait, like in photo attached...to cast an eyelash or hair prop strands (some do have them). Regular spots cannot do this. There are tech threads explaing why...
What Ray Trace cannot do...cast a soft blurred edge shadow. Do that with a shadowmap light.
Wish I had the Geep touch...lol
Message edited on: 01/20/2005 21:30
aah you mean the method used here? - http://www.caligari.com/news/news_june2004/tipsandtricks.html - mixing 2 infinate lights, 1 Raytracing the shadows, 1 shadowmapping. I think the technique can be adapted to Poser5 quite easily. (the 2nd part I think is optional. (I treat it that way in tS) or could be made using spotlights instead)
okay, I am going to experiment with this over the weekend. I remember reading about this on some other thread. Put two lights in the same spot, one shadow, one RT. I will continue to "unpack" your syntax and look for other pertinent threads. I really want eyes that glow. I've got to learn the shader nodes better. ::::: Opera :::::
Attached Link: http://www.caligari.com/news/news_june2004/tipsandtricks.html
strange.. it works here ok..trying again edit - tested and works here.. if not, goto www.caligari.com then news / newsletter / June 04 / tips and tricks
Message edited on: 01/20/2005 23:27
Caligari link working and a cool clear tutorial.Click on link attached.
::::: Opera :::::
Ceba, Glad you got some fuel. Remember lights have to be developed like a character...when you get something you like, save the lights to your light library. click all subsets 1st. Khai, Same deal. And you can continue to drop RT shadow until it works for your scene. It's the most powerful light (in poser) with the biggest problem. It's unblurrable. Opera, "glowing eyes" , teeth, mouth and ears are my downfall. I know what you mean (with shaders), but the downside of sm spots are they leak light like a sob and give you those probs.
Render P5 Firefly Production using HyperReal Shader
