Bryce F.A.Q (Last Updated: 2025 Feb 02 12:16 am)
Wood? I don't see any combustibles. The textures look great as does the fire. May want to scale down the brick size inside the fireplace. They're traditional style bricks but on a bigger scale than the outside and it throws the eye off a bit. The inside is usually fire brick(heat resist) and the outside dress brick(standard), normally the same size. Occasionally the inside will be fire block which are less rectangular. Nice work, Keep us updated. ICM
___
Ockham's razor- It's that simple
I am trying to do the wood part into the fire and it does not come out right. I added a cylinder put a wood texture on it and then put the cylinder inside the fire, in the middle of the spheres, but the wood comes out as if it was in front of the fire, like outside. How can I fix that? Is there a trick to the firewood? thankx
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=864362
Aye, it's getting there, be patient! Fire is difficult to do. Remember that those materials for fire came from seven years of Brycing, they didn't happen in one night... We'll try to cut down your development time, if possible. Yeah, you need some wood in there! The link goes to an older image of mine, might give you some ideas...This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
