Mon, Nov 25, 9:53 PM CST
Subject: Changing .pz2 file to .cm2 files?
Wylder ( ) posted Sat, 22 January 2005 at 6:25 AM ยท edited Thu, 31 October 2024 at 5:09 PM
Hoping someone can help me with this. I'm in the process on moving my MAT and MOR pose files from the poses library to the camera library. I figured out how to "batch" change the files in the Command Prompt window on my PC, using the REN function to change *.pz2 to *.cm2. Is there a way to change all the files in all the subdirectories of a particular directory all at once (on a WinXP Pro PC)? This is really getting tedious.... Thanks for your help! Wylder
SamTherapy ( ) posted Sat, 22 January 2005 at 6:38 AM
You can do it in DOS, or if you have ACDSee you can batch rename from there.
Wylder ( ) posted Sat, 22 January 2005 at 6:42 AM
Cool! How about a mini-tut for both methods? :)
ENGELKEN ( ) posted Sat, 22 January 2005 at 6:50 AM
Attached Link: http://www.senosoft.com
Too easy...
The free version of P3dO Explorer 1.7.5
(earlier versions work too)
Select subdirectory in P3dO then,
Go to "Tools", then "Pattern Renamer"
Wylder ( ) posted Sat, 22 January 2005 at 6:52 AM
Very, very cool! Thanks so much!
Bobbie_Boucher ( ) posted Sat, 22 January 2005 at 10:02 AM
The problem with this whole idea is that your camera library will quickly become full as well. I did this briefly, and decided against it. A better solution would be to get PBooost and really take charge.
Wylder ( ) posted Sat, 22 January 2005 at 10:08 AM
And PBooost is... what? How does it help? I have ProPack, so no extra runtimes allowed. Thanks.
Bobbie_Boucher ( ) posted Sat, 22 January 2005 at 11:21 AM
Look for PBoost in the Marketplace. (do a search for hogwarden) PBooost allows you to create Banks so you can better organize your stuff. Poser only sees the Bank you selected. Switch back and forth when you work. I found PBooost to be invaluable for Poser 4. See the Product Description for futher info.
