You can do it in DOS, or if you have ACDSee you can batch rename from there.
Attached Link: http://www.senosoft.com
Too easy...http://www.senosoft.com
The free version of P3dO Explorer 1.7.5
(earlier versions work too)
Select subdirectory in P3dO then,
Go to "Tools", then "Pattern Renamer"
Look for PBoost in the Marketplace. (do a search for hogwarden) PBooost allows you to create Banks so you can better organize your stuff. Poser only sees the Bank you selected. Switch back and forth when you work. I found PBooost to be invaluable for Poser 4. See the Product Description for futher info.
Hoping someone can help me with this. I'm in the process on moving my MAT and MOR pose files from the poses library to the camera library. I figured out how to "batch" change the files in the Command Prompt window on my PC, using the REN function to change *.pz2 to *.cm2. Is there a way to change all the files in all the subdirectories of a particular directory all at once (on a WinXP Pro PC)? This is really getting tedious.... Thanks for your help! Wylder
