Sat, Feb 15, 4:16 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Subject: Trying to keep head facing camera
DocMatter ( ) posted Sat, 22 January 2005 at 10:30 AM ยท edited Thu, 13 February 2025 at 7:55 AM
I'm trying to keep V3's head facing the camera during an animation (she's just walking). I tried setting her head to "point at" the active camera (the aux camera), but then she looks straight down at the floor. Any suggestions?
geep ( ) posted Sat, 22 January 2005 at 11:12 AM
Um, ... put the camera on ........ the floor? ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Qualien ( ) posted Sat, 22 January 2005 at 12:01 PM
I also have thought about a way to keep a camera pointing at a head automatically, it would often be useful. I don't know much about figure creation and Cr2s, but is there some way to attach something to a V3 head which would inherit the head's bends, trans, and rots? If so, that thing could be the parent of the active camera, it would seem.
geep ( ) posted Sat, 22 January 2005 at 1:43 PM
Actually, if you just change the direction in which the head bone is "point"ing, and then point it at the camera, I believe you will find that the head will always look straight at the camera ... even if it causes a broken neck! ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Qualien ( ) posted Sat, 22 January 2005 at 2:11 PM
Many thanks, Dr!!! This works like a charm, except of course, if you move the camera too far, you do throw the neck out of joint, as you warned (maybe you are a chiropractor, eh doctor?)
geep ( ) posted Sat, 22 January 2005 at 3:44 PM
cheers,
dr geep ... :o]
edited 10/5/2019
deci6el ( ) posted Sun, 23 January 2005 at 8:08 PM
Without changing bones, You could "point at" a small box prop, parent the box to the camera and translate the box up until the head was the level you liked it. I do something similar with the eys so I only have to move the box to move both eyeballs at the same time.
Nance ( ) posted Sun, 23 January 2005 at 10:03 PM
too lazy to test but seems if you did it that way (pointing at box above head that's parented to cam) and X-Trans'ed the cam, that the head would tilt (z-rot) rather than twist (y-rot) -- no?
deci6el ( ) posted Mon, 24 January 2005 at 12:49 AM
Yeah, I'm trying to keep it all in my brain and not go into to Poser to see how it works BUT I know it works with the eyes but there, the box is parented to the head and the eyes point at the box. If the head points to the floor when you say, "head point at Aux cam" my thought was just change the target and then if the head is pointing at the floor you can move it wherever until your head is back in the desired position. Parent the box to the cam and now if the cam moves it will take the head target with it. As for the order of rotation...? Ok, I'll go try it. Be back in a sec. or two.
deci6el ( ) posted Mon, 24 January 2005 at 1:08 AM
Yeah, well, OK, ouch! With a few minutes of dabbling it certainly seems easier to move the bone as the Dr. said or just keyframe the head to look at the cam. I know I don't like to go in the setup room and start mucking with bones but if that's what it takes... I also tried having the box point at the camera as it hovered above the head but that didn't seem so elegent either, although on paper it seems like it should work. Ah, well. That's all the bad advice I'll spread for today.
