Fri, Dec 27, 4:10 PM CST
Subject: Depth of field??
Shiollie ( ) posted Sun, 23 January 2005 at 7:08 PM ยท edited Thu, 26 December 2024 at 11:49 PM
I have been working on this all day... I need the front of my image clear for the subject while the background needs to be slightly blurred... I cannot seem to figure this out. I can post a WIP if you need one to help. Thanks for all the help on this forum!
Essexboy ( ) posted Mon, 24 January 2005 at 2:14 AM
If you group everything in the scene except for whats at the front then make the camera blur only what is grouped essexboy
karlm ( ) posted Mon, 24 January 2005 at 3:10 AM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12368&Form.ShowMessage=370638&Reply=370921#11
Here's a link to one of my ancient posts that should hopefully clear things up for you. It was in reference to Vue 3, but should apply to all versions.
Shiollie ( ) posted Wed, 26 January 2005 at 8:28 AM
Thanks Karlm, I looked at your post and it did help alot :) I just cannot seem to get it right, it may be that it is already such a tight shot that I cannot really use the DOF anyway.I have adjusted the picture so that I am using some of the subjects to get the depth that I need. Thanks to all!
karlm ( ) posted Wed, 26 January 2005 at 3:33 PM
Note that you will often use a VERY low percentage for DOF. Sometimes 1% is too high, depending on the scale of the scene. But, if you've got it working the way you want, then it's all good!
