Wed, Feb 26, 2:13 PM CST
Forum Moderators: RedPhantom
Subject: Gel Projection
NHArtist ( ) posted Mon, 24 January 2005 at 7:35 PM ยท edited Wed, 26 February 2025 at 2:12 PM
Hello, Is it possible in Poser 5 to project a bitmap or animation(or gif anim) with a light source? I would like to, for instance, project a water caustics image on some underwater figures to give that look of water surface waves on the props and/or figures. Does the image need to be a particular size or resolution? Transparent colors etc.? I haven't seen anything in the manual.
mateo_sancarlos ( ) posted Mon, 24 January 2005 at 7:42 PM
Since a stationary mask or filter works with ordinary spotlites, you can use one that's a very long rectangle, and move it across the front of the lite. Of course, it would be much better to use an animated transparency as texture, but I don't know if it works.
Ajax ( ) posted Mon, 24 January 2005 at 9:09 PM
Just plug the gel straight into the colour channel of your light material.
Ajax ( ) posted Mon, 24 January 2005 at 9:15 PM
Note: for animation you'll need a movie node instead of a tile node. Resolution is no problem, but I think you need the animation in avi format. I don't think animated gifs are supported.
Little_Dragon ( ) posted Tue, 25 January 2005 at 2:51 PM
Not any more ....
