Thu, Feb 6, 4:17 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: How can I keep the same scripts in the Python Scripts box in P4PP?
Tguyus ( ) posted Wed, 19 January 2005 at 1:47 PM ยท edited Sun, 17 November 2024 at 3:25 AM
I'm thinking there must be a simple solution here. I like being able to load my favorite scripts into the Python Scripts box in P4PP for a session. But when I reopen Poser later, the list of scripts goes back to the default set (i.e., Prop Samples, Geom Mods, etc). I tried saving the preferred state with my scripts loaded but they still didn't stay put. Do I have to load my favorite scripts each session?
Thanks! TG
PhilC ( ) posted Wed, 19 January 2005 at 2:00 PM
Open the buttons.py in a text editor and edit the paths to your preferred scripts. Best backup a copy first just in case you want to restore the original.
Tguyus ( ) posted Wed, 19 January 2005 at 2:53 PM
Thanks PhilC! [got thrown a little at first since the buttons.py file didn't have references to filenames or paths, but I found a file named mainbuttons.py which looks like it handles the python scripts button box] cheers... TG
ockham ( ) posted Thu, 20 January 2005 at 11:20 AM
Attached Link: http://ockhamsbungalow.com/python/manual.gif
For a bit more detail, look at this picture.... Also consider buying Hogsoft's Python Library Organizer. Not free, but truly works wonders if you're going to use Python often. I don't have the exact link, but it's in hogsoft.com
My python page
My ShareCG freebies
Tguyus ( ) posted Thu, 20 January 2005 at 1:12 PM
ockham-- The manual.gif file was a tremendous help. Now I have my seven key scripts all set up in the Python Script box... and it turns out all seven were ockham products! I will also look into the Hogsoft organizer, esp. as my python script library continues to grow. Thanks again!
Lucifer_The_Dark ( ) posted Fri, 21 January 2005 at 3:09 AM
http://www.hogsoft.com/catalog/product_info.php?products_id=44 I bought Python Library because I got fed up having to hunt down python scripts when I wanted them now all I have to do is bring up the python script window in poser & there are all of ockham's scripts in one place :D
Windows 7 64Bit
Poser Pro 2010 SR1
Connatic ( ) posted Fri, 21 January 2005 at 6:57 PM
One great feature of Hogsoft's Organizer is the ability to attach notes to the scripts. I copy the readme's into the notes section.
layingback ( ) posted Mon, 24 January 2005 at 10:45 PM
I'm very glad to hear that someone likes that Notes feature! ;-)
Connatic ( ) posted Mon, 24 January 2005 at 11:00 PM
The whole point of the Organizer is to eliminate time-wasting searching. Setting up the notes stops me from having to search for the read-me's for some of those complex Ockham scripts. I have been using Particles2 and MetaForm, plus scores of Ockham's and many other scripts. Hogsoft's Organizer saves me hours every week. It's a great utility.
layingback ( ) posted Tue, 25 January 2005 at 8:50 AM
Great, that was exactly how I expected that feature to be used when I pushed for it. I'm pleased some have seen the advantages of exploiting it.
hogwarden ( ) posted Wed, 26 January 2005 at 10:15 AM
Hehe... @layingback: You said the script notes would be useful:) Glad you find it useful, y'all! H:))
