Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 3:46 am)
OK, my last did not make any sense, so here it is completely written out. Pardon me. stupid question. I have recently calculated and organized my poser freebies that I have downloaded over the years. To free some space on my HDD I needed to do something with them but I did not want to install all of them because I have literally GIGs of the stuff. So I unpacked them and put them on CDs. The problem is that I wanted them on CD to use as needed which is why I unpacked them. Now here is the funny part. How to do I use them from the CD when needed. I can't seem to get them to import as I need them to.
are you saying: you can't just copy what you need from the CD into Poser? without storing them on your hard drive? Is it a disk burn? If so, how did you burn it? If you burned it as 'data' it should transport no problem. You may need to get a ripping program though to put what you want into Poser without having to storing it back on your drive.
Yes it is a disc burn as data. I used the basic Winxp burn to make the CD. I just want to pullit straight from the Disc as needed with out adding it to the library. Starting to seem impossible. Ok so basically, it seems that it must be in the poser library in order be useable, correct? I think that should CL's next step on Improvement since there is so much content out there for the program. Hmmm, maybe there's a util or plug that will do just that, what d'you think? I should ckeck the free stuff!!
"Ok so basically, it seems that it must be in the poser library in order be useable, correct?"
Yes, to use any Poser items they will need to be in your 'Runtime' folder then to whatever sub folders they will need to be placed in. I dont think you can run them directly from a CD.
Message edited on: 01/26/2005 18:56
If you use Poser 5 you can probably organise your CD as one or more runtimes. With poser 4 I believe you are restricted to one runtime. you would need to install and remove items as required. You could possibly have a temp subfolder in props and characters and swap the contents in and out as required.
I assumed he was in P4 and that's why he asked. :)
Actually I Use both versions.
So if it the CD thing works with there being a runtime on the CD but only with P5, then I will stick with that since it is more greatly, stupendously, and deliciously powerfuller and better-er.
However, Ratscloset mentions adding the runtime. "?"
Please, explain exactly how that is done.
I know, I know, I'm such a noob!! But no one knows unless they are taught. Message edited on: 01/28/2005 19:38
So I unpacked them and put them on CDs. The problem is that I wanted them on CD to use as needed which is why I unpacked them. Now here is the funny part. How to do I use them from the CD when needed. I can't seem to get them to import as I need them to. Any suggestions? Or this possible to do at all?
