Silly question :) did you change the refraction color? John.
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
I have a couple of water materials, the background colour on the reflect node is a nearly black shade of blue.
The reason I left it that colour was to be a kind of alarm bell. When you see pink, you're supposed to go "hey, something's wrong". In this case, what's wrong is that there's nothing for the water to reflect - no sky, no roof, nada.
If you check the readme for the shader pack, you'll see a list of ways you can handle the problem. Changing the background colour to something less obtrusive is one of them, but the best thing would be to include a sky dome or some other sort of enclosed prop in your scene so the water has somethig it can reflect. You can also feed a spherical environment map (ie a reflection map) into the background channel. All you need is a reflection map that looks like the sky.
Message edited on: 01/29/2005 17:13
View Ajax's Gallery - View
Ajax's Freestuff - View
Ajax's Store -
Send Ajax a message
Glad you like it :-)
Ajax's Store -
Send Ajax a message
![file_175962.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_175962.jpg)
I'm having a problem that I'm hoping somebody can help with.I've got Ajax's free raytraced water texture, and I'm working on a scene that uses a mirror. The water looks fine in the actual pool, but it's got this funky purple color in the reflection (it's the same color that is the "background" color on the refract node that is plugged into the refraction_color).
I've tried playing around with the settings on the water, I've tried moving the lights and camera, I even bumped up the "raytrace bounces" setting for the render all the way to 64, thinking that might be the problem (since the water uses raytracing and the mirror does for the reflection), and I can't seem to get it to change.
Any ideas?
