Ah, welcome to the age old Poser problems. No, DAZ Studio won't do that (as of yet.), that's why DAZ made that Turbo plugin for Bryce 5, which will do what yer looking for. But, otherwise, yes you have to select the various parts and basically re-texture them. You can use the "Grouper" free utility which helps this Poser problem. I don't have my pc up and running so I don't have all my screenshots, but I am sure you're about to get a LOT of info....;o) AS
Contact Me | Gallery |
Freestuff | IMDB
Credits | Personal
Site
"I want to be what I was
when I wanted to be what I am now"
*Make sure to use deafult Poser settings when exporting, meaning that one window that pops up and lets you check boxes...don't check any more than what is checked. This will make it so you the amount of objects that V3 and her outfit are made out of are as a least amount as possible, so you have to mess with less objects in Bryce. Lol, hope that makes any sense.... AS
Freestuff | IMDB
Credits | Personal
Site
You know,.........I've never had any problems with Bryce reading the textures from Poser(I'm using ProPack),.......although I generally want to adjust the texture levels (abmience, bump and so on) and I generally check the box that says "use body part names" or something like that. I've never understood why so many people have so many problems with importing textured P figures into Bryce. Daz Studio has an annoying habit of putting the bumpmaps full out at 100% for me but that's all. I always export the object to the same folder as the textures and everything loads fine. I suppose I should consider myself lucky !
"Any club that would have me as a member is probably not worth joining" -Groucho Marx
Aye, I'm always re-texturing, layering in procedurals (DTE) mats with any, and I mean ANY texture map. The more layers you use, the more realism you'll achieve. I've never tried Turbo, does anyone know if it will allow you to set up your Bryce mats beforehand? I always change a few key attributes, such as Diffusion and Ambience, they are usually at 100 when I import from Poser 5...
I tend to agree with ICM and LSD... I got that Turbo plugin and used it once. Just didn't like the results. I see much better results when I take the extra time and tweak the textures and attribute values as LSD mentioned. And Like ICM said... in the end it is definitely worth takin' that extra time.
There are 10 kinds of people: Those who know binary, and those who don't.Â
AÂ whiner is about as useful as a one-legged man at an arse kicking contest.
Now to bed, catch you in the pm....
Bryce Forum Coordinator....
oh, the old eye problem- texture the outermost layer of the eye with the clearest glass mat, and that should fix it..if not, I use the Lego colors mats (of all things) for quicky eye textures, though Poser has eye textures that look a lot better. At least Daz Studio is free..;)
Actually, with this particular model and pose, the white eyes look kinda cool.
The eyes I thought had an outer layer, but all that shows is the 'eyeswhite', 'cornea' and 'iris'...maybe I'll give her cyborg eyes, the ones with the cross hairs....now what series/movie had cyborgs with those types of eyes? Anybody?
If I export as an obj. I'd have to texture each individual little freakin' part of her suit, and, her face and hair...is there some export function to get it all and just load it in? Is DAZ Studio supposed to be able to do this, so I load a fully textured V3 into Bryce?.....
Any insights, tips, or info on this would be appreciated....
