Attached Link: http://www.morphography.uk.vu/bumpmaps.html
Just turning a colour map into greyscale is not the 'right' way to make a bump map, inverted or not; although lots of people do this, and a greyscale version of your texture might be a starting point for a bump map.The principle of the bump map is: white bits are sticking out, black bits are depressions, and mid-grey is level. A proper bump map will be edited by hand, although I've never made one for a figure, so that's where my knowledge ends.
In the final analysis, if it works, it's right. :) You may find the link useful...
Message edited on: 02/01/2005 04:09
I agree with what EnglishBob said. You can make a quick bump map by taking a texture and just turning it grayscale, but some things will be wrong... especially where things like eyebrows or body hair is involved. For instance, if you turn a texture map grayscale, the eyebrows usually translate to dark gray or black, which would mean their details render "concave" instead of "convex". To fix this in photoshop can be a bit tricky, but the basic notion is to mask out the eyebrows and then simply invert them (change them from black to white), or paint them over in white by hand using a very small brush size. Same goes for facial hair or body hair that may be present on the texture. Also, details like veins may need to be lightened so that they render as raised parts on the mesh surface, rather than depressed. In contrast, wrinkles should be darker in the grayscale than the skin color.
Tools : 3dsmax 2015, Daz Studio 4.6, PoserPro 2012, Blender
v2.74
System: Pentium QuadCore i7, under Win 8, GeForce GTX 780 / 2GB
GPU.
I'm working on a V3 texture - something realistic -, and wanting to know how I can make a bump map. Could I just use the texture and make it 'grayscale' and use 'invert', or do I just make it 'grayscale' and leave it alone?
I've been toying with this for a while with Poser 5 [which I have] and have seen other texture maps with the bump maps in them and they are quite different from the ones I've made.
Is there a way to either 'invert' it or make it 'grayscae'? Is there a difference or another way?
Just wanting to know.
Replies are appreciated.
JBWStar
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
