Mon, Feb 3, 2:04 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Modifiers for water
palagas ( ) posted Sat, 05 February 2005 at 7:59 PM · edited Mon, 03 February 2025 at 1:59 AM
Hi, I am making a water plane and would like to animate it, would I use a wave modifier, And if so how would I do this. Any other suggestions Thanks
misha123 ( ) posted Sun, 06 February 2005 at 4:02 AM
I would use the modifier if animating ripples in a small pond and use a terrain with a dune setting to animating waves in the ocean.
noviski ( ) posted Tue, 08 February 2005 at 11:15 AM
You can animate it using shaders too. With the Four Elements Shaders> Water: Ripples or Waves bump. On the first keyframe you set the Compelion parameter at 0% and the last keyframe put it on 100%. Adjust the type of wave you want and good luck.
palagas ( ) posted Fri, 11 February 2005 at 3:03 PM
Thanks, Is there any Tutorials on how to o this. I am new to Carrara.Thanks
noviski ( ) posted Wed, 16 February 2005 at 12:02 PM · edited Wed, 16 February 2005 at 12:04 PM
Attached Link: http://www.3dxtract.com/support/stormysea.zip
I remember a tutorial from the 3DXtract.com magazine (2004 januarys edition) from Brian Hinton. Its a great Stormy Sea scene. The link with the complete .car file is above. I hope this help you. ;-)
Message edited on: 02/16/2005 12:04
