Fri, Nov 22, 5:53 PM CST
Subject: Terrain Editor Controls
kiwi_gg ( ) posted Sun, 06 February 2005 at 1:12 PM · edited Fri, 22 November 2024 at 5:15 PM
I have never tried to use these controls (see image)before so I decided to have a play with them. Problem....???? they dont appear to be working,anyone have any thoughts on this?????
Cheers
GG.
WHO said Kiwi's can't Fly ?????
draculaz ( ) posted Sun, 06 February 2005 at 1:55 PM
they do work, you just have to keep them clicked and move your mouse around. the first is the hardness of the brush, the second is something else, it's whatchamacall it, try it out, same deal with the mouse. drac (forgetful)
danamo ( ) posted Sun, 06 February 2005 at 2:11 PM · edited Sun, 06 February 2005 at 2:14 PM
I believe the second control you have circled functions rather like the flow control on PS brushes.
Message edited on: 02/06/2005 14:14
Stephen Ray ( ) posted Sun, 06 February 2005 at 3:34 PM
The second is a pressure, flow, flux, control,
Stephen Ray
chohole ( ) posted Sun, 06 February 2005 at 3:42 PM
Yeah like if you have the first one over hard right it gives you a really hard line. Almost ditto with second, if you put it over hard right you get a straight line, tend to the left like I do you get a really soft flow.......much easier to build up a really nice terrain. The morale here is go to the left...its much softer and more true to life. Sorry about that folks...its Sunday evening here and I am leaning to the left, in fact with the alcohol intake I guess I am just leaning.
The greatest part of wisdom is learning to develop  the ineffable genius of extracting the "neither here nor there" out of any situation...."
kiwi_gg ( ) posted Sun, 06 February 2005 at 5:39 PM
Thanks Folks, I knew what they were for,just could'nt get them to move. Had another go after reading your replies and discovered that the Hardness was already max'd out on the soft side(left drag=hard,right=soft) got it all sussed now. Cheers 8) GG.
jedswindells ( ) posted Sun, 06 February 2005 at 6:45 PM
While you are experimenting,try running Paintshop or Photoshop at the same time! In editing tools you can select 'photograph' then 'copy'-minimise bryce and 'paste' as a new image into PSP. These programs give much better tools for dealing with a greyscale image - make any alterations - copy and paste back to terrain editor. Works for me! Jed.
nuski ( ) posted Sun, 06 February 2005 at 10:14 PM
Just a little hint. . . . Instead of moving the little red dot up and down to control the painted grey level. . . . Try holding down the spacebar while moving the mouse around in the editing window. When you find the level that you need . . .release the mouse button.
