Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:49 pm)
ooh...that looks great :D If you're willing to share settings and tricks, I'm willing to learn :D
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
w00t!!! I have more stuff to do play with tomorrow :D Thanks!
into a fruit salad.
Attached Link: Reflection Refraction a ball of glass TUTORIAL
_________________________________________________________
"Surrender to what it is - Let go of what was - Have faith in what will be "
Is ok Jeremy :) Nice to see you work on! P.S the nice effect of the glass you can get using another image maps for the big ball. replace the mini ball with a prop or what ever you wish.
Message edited on: 02/08/2005 00:35
Absolutely brilliant! I'm off to play :D
into a fruit salad.
Attached Link: Save me on your Hard Drive
CLICK ON THE LINK AND SAVE TARGET AS TO YOUR HARD DRIVER. Thank you I am happy you Like this. :) Cath P.S when you open this tutorial in your own browser click on F11 to get the full screen mode._________________________________________________________
Attached Link: http://www.runtimedna.com/messages.ez?forum_id=28&Form.ShowMessage=111049
Don't foget my trick on how to get more realistic reflections and reflections through a fresnel effect. -Stefan_________________________________________________________
Thank you very much nakamuram :) I forgot to add that the reflection on the grund is from the BIG BALL that I used in the tutorial it reflect fragment of the Window the rendering time was 5 min. The BIG BALL is very important for the reflections so for ''inside'' as ''outside'' scenes. Thank you for your attention and if you have any question regarding my little presentation here please feel free to ask. Cath
for water and any water surfaces outside studio, use the BIG ball with a picture from [outside] as I did in image above for the atmosphere of your scene. rescale the ground and see the setting of the reflection, use turbulence node for the waves, or animated bump maps for animations. If you use the not deep water you need to use refrect node also as in post #16 but as color under the Edge Blend use just white. You can also make it transparent a 50% if you set in figure :P :)
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2073866
Cath, you may be interested in a thread we had earlier about car paint shading, also including some HDRI trickery.Stefan it works perfect! if used speciall for one object, is quick trick, I made it much more simple, take the light colors from the image, it blend great together with the 3D ground so I am very happy you show me this trick :) More renders about I will show after my dinner :)) P.S I made jsut animation, it is just excellent!
ah why silly? I used the high res ball from the Poser5 there you have 2 versions, if you don't have the high resolution use the smoth polygons option to get the poly round. Cath
Attached Link: Tutorials Index --------- click me
Haha in place of Mec4D I wrote renderosity check the index above, you can download from there the tutorials to your hard drive, just save target as. Cath_________________________________________________________
![file_181203.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_181203.jpg)
I play around with the reflect, refraction and translucene shader nodes and got some interesting effects. Renders done without any transparency. If you wish to see the settings and little trick here regarding the true reflections let me know.Cath
Message edited on: 02/07/2005 22:41
