_________________________________________________________
"Surrender to what it is - Let go of what was - Have faith in what will be "
Hello Cath Nice Tip's ! SSS+Reflection+Spot = Cool base for Realistic Skin Shader Thank's for sharing ! I tested the tutorial of face_off, (with some modification) good for fixed image, but less conclusive for animation or global light simulation. The skin node on Poser have much more similarity with Brazil skin shader and renderman.(same 'base parameter") Has you make test ? Sorry for my "French" english ! :-) Wan
Hi Wan Thank you :) I don't tested for real the Poser5 skin node because I used the toon node for that without the line, it give much more nice effect, but I can get deeper into it as well and see what I can get with it and the spots or wood node that is also great for the deeper effect of the skin. Thanks Cath
