Sat, Feb 8, 6:21 PM CST
Subject: Ever think you're a few sandwiches short of a picnic?
pogmahone ( ) posted Tue, 08 February 2005 at 10:17 AM ยท edited Sat, 08 February 2025 at 6:20 PM
Sigh! I wanted a Joshua Tree (you know the way you do, sometimes) and searched the web for reference pics, and modelled the trunk in Wings, and wondered what kind of Bryce foliage would most closely match the Joshua Tree foliage, settled for can't-remember-what. Now, you'd think that when I was searching for a material for the trunk, and found to my surprise that there was Joshua Tree bark.......well, you'd think that might have been a clue, wouldn't you? But no. Only when I'd finished the blasted thing, and saved it to my library, did it occur to me to re-examine the list of preset trees. :insert banging head on wall smiley:
CrazyDawg ( ) posted Tue, 08 February 2005 at 10:33 AM
pog i have found the tree/bark in the tree lab is only a reference to what the trees really lok like. Take for instance the Ecalyptus bark in bryce looks nothing like the bark on any Ecalyptus trees here in Australia. So i think you did an excellent job on the Joshua tree, i'm just annoyed my scanner doesn't work any more because i have a U2(the group) poster of their album the Joshua tree with a nice image of the tree on it that you could have used for a reference pic.
I have opinions of my own -- strong opinions -- but I don't always agree with them.
ย
Quest ( ) posted Tue, 08 February 2005 at 11:05 AM
But Pog, you did an amazing job on your tree as compared to the treelabs. You do know you can change the foliage to every tree in treelab and that you can even make your own, right (user defined)? But that good work!
pogmahone ( ) posted Tue, 08 February 2005 at 11:08 AM
Attached Link: http://users.cihost.com/ata/jt/82zoom.jpg
just couldn't get the foliage to look right unless I modelled it, which would have driven up the polys a lot. You can see how fine the spiky leaves are in the attached pic
tjohn ( ) posted Tue, 08 February 2005 at 12:28 PM
Pog: I tried playing around in Wings to make the spiky balls. These are about 732 polys each. I just extruded (normals) a default sphere in point mode and then changed to poly mode and deleted all the non-spike polys. Then I moved (normals) the large ends (already selected after deleting the non-spike polys) to the center of the ball. Might work; you could alter the shape in Wings by deforming in point mode to look more organic. Hope this helps. John
tjohn ( ) posted Tue, 08 February 2005 at 12:31 PM
I used the Joshua tree shape and thickened the trunk and altered the distribution. I tried to fix the bark texture, it'll do to demonstrate, I guess :^)
pogmahone ( ) posted Tue, 08 February 2005 at 12:48 PM
That tree shape is very good. Yeah, you're right, it'd be better to do the leaves in Wings.
Quest ( ) posted Tue, 08 February 2005 at 2:02 PM ยท edited Tue, 08 February 2005 at 2:08 PM
Heres my Joshua tree right from TreeLab. I choose the Joshua tree preset, then I made sure that the Foliage was set to Joshua tree, set scale=6, number of leaves=2, distribution=bunched. Set tree shape gravity=0 and branch trunk distribution=5. In the Foliage; texture; material; edit I made sure that the leave image was also set in the transparency dent. In the Branch/Trunk; texture; material; edit I upped the middle component scale to 320 (Basic Triangle texture).
randomness=30
Message edited on: 02/08/2005 14:08
sackrat ( ) posted Tue, 08 February 2005 at 2:04 PM
One taco shy of a combination platter ? One chop short of a mixed grill ? Actually, there's a decent Joshua Tree on the content CD that came with Bryce 5, isn't there ?
"Any club that would have me as a member is probably not worth joining" -Groucho Marx
pogmahone ( ) posted Tue, 08 February 2005 at 2:13 PM
I have the download version, don't think there's much extra content....I'll just check....No, not much useful in the Content folder, a few sample scenes, light gels, terrains.
artnik ( ) posted Tue, 08 February 2005 at 3:01 PM
How about one neuron short of a synapse?
pakled ( ) posted Tue, 08 February 2005 at 4:15 PM
no, but my elevator doesn't go all the way to the top..;) Look at the bright side, at least we're not selling tree presets in the Marketplace like some other programs do for pos(woops)...are we?..;)
Erlik ( ) posted Tue, 08 February 2005 at 4:16 PM
This is my take, with TreeLab. It's not a Joshua Tree, but it looks _like_ it. And if the eucalyptus bark from the preview stayed the same, it would be perfect for this. :-) BTW, isn't it called a yucca?
-- erlik
Quest ( ) posted Tue, 08 February 2005 at 4:42 PM
Yes, Erlik they belong to the same family/species/whatever, yucca.
Zhann ( ) posted Tue, 08 February 2005 at 4:44 PM ยท edited Tue, 08 February 2005 at 4:45 PM
Yucca's are a different plant....that's lookin awful close to a true Joshua tree...didn't 3DPlants have a Joshua tree in their collection, I could have sworn they did....hmmmm
Message edited on: 02/08/2005 16:45
Bryce Forum Coordinator....
Quest ( ) posted Tue, 08 February 2005 at 4:50 PM ยท edited Tue, 08 February 2005 at 4:57 PM
Attached Link: http://helios.bto.ed.ac.uk/bto/desbiome/yuccas.htm
According to this, the Joshua tree (Yucca brevifolia) is the largest in the yucca species. Ahhhh...yes, I see, it needs to be stumpy.
Message edited on: 02/08/2005 16:57
drawbridgep ( ) posted Tue, 08 February 2005 at 5:43 PM
Well here's me thinking Joshua Tree was nothing more than an album by U2. ;-) Phil (One book short of a library.)
Phillip Drawbridge
Websiteย
Facebook
Erlik ( ) posted Tue, 08 February 2005 at 5:53 PM
What's U2? A submarine? :-) Erlik (three oars in the water!) :-))) PS But I still like pog's phrase most. PPS Aaaah! They've got soaptree yuccas as decorative plants in my hometown! But with a very short trunk.
-- erlik
sackrat ( ) posted Tue, 08 February 2005 at 6:29 PM
How about,.........All the lights are on but no one's at home ?
Incarnadine ( ) posted Tue, 08 February 2005 at 6:56 PM
I think there was a good one on the bryce 4 goodies cd. Will look later.
pogmahone ( ) posted Wed, 09 February 2005 at 12:52 AM
trying to remember a few more 'not the sharpest knife in the drawer' 'not the full shilling' 'a few bricks short of a load' The foliage from the lab looks pretty good - and tjohns gnarly trunk is particularly effective! I haven't messed much with the tree lab, didn't realise you could get such contorted branch shapes.
pakled ( ) posted Wed, 09 February 2005 at 11:57 AM
U2- an spyplane named after a popular Irish band...;)
tjohn ( ) posted Wed, 09 February 2005 at 12:37 PM
"Not the sharpest tool in the shed" "Thick as a brick" "Dumber than a sack of hammers"
alvinylaya ( ) posted Wed, 09 February 2005 at 12:47 PM ยท edited Wed, 09 February 2005 at 12:49 PM
Here's my take on it. I think you need to postwork to make that shaggy lookin bark.
Message edited on: 02/09/2005 12:49
tjohn ( ) posted Wed, 09 February 2005 at 12:55 PM
Those are very nice, Alvin. I'll have to archive those settings and make a .bto
pogmahone ( ) posted Wed, 09 February 2005 at 1:37 PM
Where the heck did my post go :^( I posted about how great all those Joshua Trees looked, and that it seems like the TreeLab was maligned.
Allen9 ( ) posted Wed, 09 February 2005 at 6:02 PM
My current favorite is "dumb as a box of rocks".
sackrat ( ) posted Wed, 09 February 2005 at 6:23 PM
Or,......."Doesn't have the good sense God gave a toaster".
Quest ( ) posted Thu, 10 February 2005 at 4:03 PM
"A day late and a dollar short"
