Tue, Jan 14, 10:09 AM CST
Subject: What do you think anim 1.3 meg
Essexboy ( ) posted Tue, 08 February 2005 at 4:59 PM ยท edited Tue, 14 January 2025 at 10:09 AM
Attached Link: http://www.freewebs.com/skincanvas/test.WMV
hHello I am making a movie about a game dod so take a look just right click and save as essex
Message edited on: 02/08/2005 17:00
palagas ( ) posted Tue, 08 February 2005 at 5:03 PM
Good Work
HellBorn ( ) posted Wed, 09 February 2005 at 5:37 AM
Not bad :) Did you use Particle Illusion for explosions and fire? If so, I did notice some explosions looked a bit strange as the explosion did continue downwards below where a ground level whould had been expected. If you need explosions and other stuff to not do that there is something in Particle Illusions that I think is called reflectors or deflectors or something. If you place those below the explosion when rendering the particles will bounce when hitting it witch might look more realistic.
Essexboy ( ) posted Wed, 09 February 2005 at 5:40 AM
lo Thanks for the kind words and thanks for the tip as i wonderd if that was possible again many thanks il av a look and repost when and if i can make better regards essexboy
4dogday ( ) posted Wed, 09 February 2005 at 3:34 PM
Where did you get Particle Illusion or what ever you used for the explosions, The fires burning at the end are excellent.
HellBorn ( ) posted Thu, 10 February 2005 at 12:45 AM
For my part I got it from a Magazine quite a while ago. Sorry to say that back issue is sold out. So if you cant find it on a Magazine then you will have to buy it. Latest version is 3.0 costing $399 but there is also a 2.0 SE version witch works for 30 days and cost $99 (Windows and Mac) to buy in case you like it and think it has the features you need. http://www.wondertouch.com/default.asp If you search this forum for Particle Illusion you might find my old posts on it with some examples I did after getting my hands on it.
Dale B ( ) posted Thu, 10 February 2005 at 6:44 AM
True, but that $399 buys you a -lot-. Fully configurable and creatable emitters, the particle blockers, alpha channel export, much larger output capability, and access to a large library of effects posted on their website. The demo doesn't do the actual program justice by a long shot...
