Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Yes, it can be done. But be careful, P4/PP can't handle more than 255 items per folder. There's another thing to watch out for: the !INJ All Morphs and !REM All Morphs poses (the V3 ones) do not call the hidden pose files in the !DAZ folders directly off the runtime, they call the normal pose files in the Pose libraries. You'll have to edit those files to point at the right PZ2 files. I decided to change the !INJ/REM All Head/Body (four files) so that they call into the special !DAZ folders off the runtime root. Now I can organize the INJ/REM folders just the way I want without having to edit them. PBooost may be the thing for you. It allows you to organize your libraries into "banks" of manageable size. Or upgrade to P5. Not only can P5 handle bigger libraries, it also has a hierarchical library structure which allows the user to really organize his/her stuff in a logical way. A few more P5 pluses: a much better texturing/shading system, dynamic cloth, raytracing, image based lighting, multiple runtimes (a sort of PBooost built right into the program), motion blur/DOF built right into the render engine, etc. etc. etc. But since P6 will be releaed within a few months, it may be worth waiting for P6. A little caveat about P5 (and probably P6 too): it needs a pretty fast machine with a decent amount of RAM and a modern OS. Forget about running it on Windows 98 on a P2 400 Mhz with 128 Mb RAM...
I run WinXp on 700mhz with 512 ram. My problem with P5 is that it calls for 1224X812 or whatever resolution. While my monitor can handle that resolution my eyes can't. As a result I went back to PPro. And I just went to the eye doc who said my eyes are fine, no new glasses needed. Hmmm, so why can't I see better? I'd love to go back to P5 but all that smaller print and stuff is just too hard on my eyes. I tried P5 at 800X600 but then the edit windows were too large and couldn't find the buttons needed for clicking this or that...sigh. Thanks for the reply.
P5 should be pretty usable on a 1024x768 resolution - which is a good resolution for a 17" CRT or 15" TFT. Higher is better (I run at 1600x1200 on a 19" CRT).
Hi, I've managed to overlaod my pose library and now find it hard to open some folders. Is it possible to clean it up by taking all those !dazM3 and !DazV3 folders, putting all their files into one folder? I know it won't work to put the folders into one main folder but if I just put files together into one folder? I'm using Poser Pro pack. I'll bet there are about thirty or forty of those !Daz folders for apiece for M3 and V3...sigh. Thanks for any advice.
