Attached Link: http://www.turbosquid.com/
Turbosquid is at the link, you need to be a member to download but membership is free. If you click on search and then mocap (at turbosquid ) it will show the bvh files. If you are unsure which ones to use you could just download all the free ones and try them out. They are quite small files.Dont bother with the fbx files, they wont work in poser. To use the bvh files, load your figure and add any clothes that you want. Then in the file menu select import and bvh motion, it will ask you if the arms are aligned in x or z choose x and wait and see if it works properly, if it doesn
t work load the bvh file again and select z. You should also select scale automatically.
Hi, I would like to ask if anyone can tell me where to find some free poses for animations? Thanks in advance. Hugs Elin.
