Sun, Jan 26, 1:26 AM CST
Subject: Lights Dilemma in Poser
moushie ( ) posted Sun, 07 January 2001 at 3:49 PM ยท edited Sun, 26 January 2025 at 12:45 AM
Does anyone know how to work around this? My scene is simple, with three lights all "locked." But when I replace a character the lights all change position. I've tried saving the character first with no lights, but it makes no difference.
raven ( ) posted Sun, 07 January 2001 at 4:50 PM
What about setting up your lights, and then saving the lights? Then you could replace characters and apply your lights.
Nance ( ) posted Sun, 07 January 2001 at 6:31 PM
That's curious. Why are they changing at all? Are they perhaps parented to the figure -- or to some other prop that is parented to the figure that you are changing?
shadownet ( ) posted Sun, 07 January 2001 at 6:33 PM
Are you using the point at command by any chance? If so, turn it off and manually point your lights as you want them. Otherwise when you delete or replace the figure that the light is set to point at, the lights will reset to the current dial settings because the object pointed at has been removed.
moushie ( ) posted Sun, 07 January 2001 at 7:26 PM
Good answers all -- but the culprit was the "point at" command. Sincere thanks to everyone for taking the time and trouble.
