Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:03 am)
An example is the bloodrayne outfit ( http://www.renderosity.com/freestuff.ez?Form.Contrib=specs2&Topsectionid=0 ) it says for victoria 3 (which I just got from daz3d) When adding the top then setting it to conform to the victoria 3 figure, the top is a little to small on the z scale. And the boots don't cover the feet even when conformed. I notice this with a lot of Victoria 3 cloths.
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
I think I know what the problem is. It looks okay in the "default" position, but if you pose her, there's a lot of poke-through.
I'm afraid that's pretty normal, especially with freebies. It's not easy to make an outfit conform to every position. The people who can do it generally charge money for their work.
They are smaller, especially the older outfits. The new V3 SAE from DAZ is more muscular and is hard to resize some of the outfits. The older outfits for V3 do sometimes fit V2 better because V2 is slimmer. I just figured out how to do the boots in V3 and used it for my gallery. You have to morph the feet & toes down as much as possible. I hate making body parts invisible. I have boots like that, that do the samething in my renders.
Message edited on: 02/11/2005 18:46
V3 hasn't gotten bigger. I still have the original V3, and she's the same size as V3 SR1, SR2, and SAE.
It might be that some very old outfits were made before SR1, and that might cause some fit problems (when the figure is posed). But I think it's just normal poke-through. Poke through is always a problem with conforming clothing - so much so that it's addressed in the Poser manual.
Some clothing has JCMs (joint-controlled morphs) that help it fit when posed. (This tends to work better with P4 than P5.) And some have other special morphs that help with the fit. (Especially skirts, capes, and such.) But freebies tend not to have such things.
Some ways to handle poke-through:
As Karen said, turn body parts invisible (in the hierarchy editor).
Scale the items slightly. If V3's breasts are poking through, dial them a little smaller, or dial the clothing a little wider, or both.
Use magnets to pull the clothing into place.
Attached Link: http://www.renderosity.com/freestuff.ez?Form.Contrib=SnowSultan&Topsectionid=0
Yes, that was just a process of loading V3-SAE and adding and conforming the clothing items, then rendering with the P4 renderer. I use one of SnowSultan's light setups as my default. The default Poser light settings are just...ick."you are terrifying
Shire
V3 hasn't gotten bigger. I still have the original V3, and she's the same size as V3 SR1, SR2, and SAE. Not that V3 SAE is bigger persay, just that I find it to be much more muscular than the previous V2 or V3. I use V3 SAE in P4 so that might make a big diff, as far as how some of the cloths fit on her.
It may have been made around the V3rr figure she is a touch smaller then teh full version, and I found this out the hard way, not all clothing made on the rr figure will conform properly on the sr1 or the sae figure.
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
all the outfits I download seem to be smaller than the default V3 figure. Some are easy enough to resize but others I can't get to fit :( Anyone have any idea what I'm doing wrong?
