Tue, Nov 26, 3:56 AM CST
Subject: Need help with tree roots
jrcejaspulido ( ) posted Fri, 11 February 2005 at 6:15 PM · edited Tue, 26 November 2024 at 3:19 AM
I want to hide the roots of the trees in Bryce. Does someone knows any trick to do this ?
Aldaron ( ) posted Fri, 11 February 2005 at 6:38 PM
Yes, sink it into the ground :)
jrcejaspulido ( ) posted Fri, 11 February 2005 at 6:45 PM
I need some trees without roots, because I want to use them as branches for make a big tree. I had sank then in the main trunk ;-) but they still appear here and there.
Flak ( ) posted Fri, 11 February 2005 at 7:19 PM · edited Fri, 11 February 2005 at 7:21 PM
Attached Link: http://uqconnect.net/wasteland/tut/tree_tut.html
Try that. Scratched that together a while ago for someone else that was trying to do the same thing. Thats my method of doing it - i.e. use an alpha map to "cut off" the bottom of the tree (worked on my ents with guns pic). Hope it helps.
Flak (Back)
Message edited on: 02/11/2005 19:21
Digital WasteLanD
jrcejaspulido ( ) posted Sat, 12 February 2005 at 6:15 AM
Thanks a lot Flak. As you say in the tut, you have to play a bit whit the alpha maps position, but it works great. Now, lets see if I can get some real big trees with this trick. Juani
Ang25 ( ) posted Sat, 12 February 2005 at 8:56 AM
Another tut to try, thanks :-D Hi Juani, Glad to see you posting in the forum, welcome! Angela (ps check out the bryce chat maybe 8 hrs from now, hope to see you there)
Aldaron ( ) posted Sat, 12 February 2005 at 9:07 PM
Actually that was the same idea I used in my metaball oak trees I did some time ago. The file for the tree was too large to use in most scenes except in very small numbers :)
