Mon, Feb 3, 6:55 PM CST
Subject: render options???
Trel ( ) posted Mon, 14 February 2005 at 3:57 PM ยท edited Mon, 03 February 2025 at 6:50 PM
do you know how you can display the document in different ways such as wireframe or smooth shaded? Is there any way to apply those settings to rendering as well?
xantor ( ) posted Mon, 14 February 2005 at 4:06 PM
If you make an animation you can render with display settings to render the picture (I think that you can render a 1 frame animation).
Fugazi1968 ( ) posted Tue, 15 February 2005 at 12:55 AM
I dont think you can render in wireframe but you can come close, in p5 anyway. If you select the wireframe view, then click on Render - Anti Alias Document. That cleans up the display window which you can save using export - image. You can do the same with any of the document window styles. Alternatively you could make a wireframe texture by simply loading in a blank uvmap template, that might be a more versatile option. Take care John.
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
Fugazi1968 ( ) posted Tue, 15 February 2005 at 1:02 AM
Ooops :) to display in wireframe (again this is p5) you use the document display styles. They are a line of spheres on the bottom left of the screen. John.
xantor ( ) posted Tue, 15 February 2005 at 6:38 AM
You can change the display mode of seperate figures, I had a problem once that had one figure wireframe and the rest were normal solid objects because of that setting.
Trel ( ) posted Tue, 15 February 2005 at 7:17 AM
can you also use it to render/antialias in the cartoon mode?
Fugazi1968 ( ) posted Tue, 15 February 2005 at 11:47 AM
The anti alias option will work on any display mode :)
