I dont think you can render in wireframe but you can come close, in p5 anyway. If you select the wireframe view, then click on Render - Anti Alias Document. That cleans up the display window which you can save using export - image. You can do the same with any of the document window styles. Alternatively you could make a wireframe texture by simply loading in a blank uvmap template, that might be a more versatile option. Take care John.
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
Ooops :) to display in wireframe (again this is p5) you use the document display styles. They are a line of spheres on the bottom left of the screen. John.
The anti alias option will work on any display mode :)
do you know how you can display the document in different ways such as wireframe or smooth shaded? Is there any way to apply those settings to rendering as well?
