Fri, Jan 10, 3:05 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: Make hair the hair fit vicky
timnjen ( ) posted Mon, 08 January 2001 at 1:14 AM · edited Fri, 10 January 2025 at 3:00 PM
How do I translate the position of the p4 hair to fit the vicky model? . . . I have looked every where in poser to fix it. . . Are the p4 hair props not going to work with vicky? Setting the hair's parent makes no difference as far as I could tell.
Jaager ( ) posted Mon, 08 January 2001 at 6:08 AM
The scaling difference is not very large so this should not be your problem. Select the hair prop. Change the parent to none or universe (whichever applies) Use the X-Y-Z trans dials to move it. Rotate if necessary. scale as needed When it is positioned properly - re-parent to the head. A parented prop's location is controlled by the parent group ?
timnjen ( ) posted Mon, 08 January 2001 at 7:26 AM
thanks got to try that. . . I will when i get back from my trip tuesday night. Is there a way to get around all the hair not working with vicky like it should or is it a matter of buying all new hair for vicky?
Helen ( ) posted Mon, 08 January 2001 at 8:06 AM
Attached Link: http://morphs.bbay.com/html/hair.html
You can download the default hair that comes with Poser here http://morphs.bbay.com/html/hair.html It has been resized so that it fits both Michael and Vicki.. Just put it in its own hair directory.. As there is no read me I don't know who did these but it saves a lot of hair hassle. The hair is at the bottom of the page
Senior MarketPlace Tester
If anyone sees a mind wandering aimlessly around..... It is mine.  I want it back.
Jaager ( ) posted Tue, 09 January 2001 at 12:50 AM
You are missing something basic here. The hair props will work with any character with a head. They may not fit very well, to be sure, but they will work. If you are using a hair prop from the "Hair" Library and it has been placed on a figure and parented to that figure's head, then you have taken the prop out on the branch of a tree and done special adaptations to it. To use this prop on an entirely different figure, you must back track to the simple prop and go out a different branch to adapt it to the new figure. This has not been obvious before Vicki, because P3-P4-Casual-NYW-Eve are all the same head, so it has not been necessary. You would have to do this if you wished to fit the hair to the P3/P4 male or to Mike. The rescaling is a minor thing. If you are looking for simple "fire and forget" type steps, you will seriously restrict the possibilities in Poser open to you.
