Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2086641
But, then again, I might decide to open the doors for a view inside. What I've been doing is using Doc's tutorials and reproducing the buildings on my grandfather's farm. This garage, part of the smokehouse, and the house are the only buildings still around.Message edited on: 02/15/2005 09:31
Try this approach. Its just the one polygon square prop from the library with your texture. I also used it as the bump map. If you have Poser 5 you could add displacement. If you need to see the ridges better use a six sided cube elongated and scaled for each. No smoothing but you could split the verts in UVMapper. Just out of curiosity how many polygons is in your panel?
Ahh, it would appear that you are becoming a master Poser builder, grasshopper!
Congratulations !!!
cheers,
dr geep
P.S. The secret is knowing where the origin is and using that to align and position the pieces before you "glue" 'em together. It looks like you've got it.
cheers,
dr geep ... :o]
edited 10/5/2019
Thanks Doc, I didn't think about the origin but I'll remember that now. Your a great teacher for sure. Because of that, I'm able to do stuff in Poser that I never thought I would be able to do. Looks like I need to go back and redo the roof on the smokehouse and the barn now. Thanks again.
Message edited on: 02/16/2005 09:15
