Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 3:55 am)
I have the feeling this might also have to do with the render dimensions as compared to the document window. No matter how much you adjust the camera, you are not going to get what you want if document window and render dimensions don't match.
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
Right ... you need to change the dimensions of the document window, and make it more like a portrait ... you know, like an 8 x 10 photo. I think the command is Window > Document Window Size, and then you can enter new document dimensions. Try something like 400 wide and 500 high (which would give approximately the same aspect ratio as an 8 x 10 photo). You'll probably have to adjust your camera again afterwards.
Message edited on: 02/16/2005 01:06
Message edited on: 02/16/2005 01:22
Right ... you need to change the dimensions of the document window, and make it more like a portrait ... you know, like an 8 x 10 photo. I think the command is Window > Document Window Size, and then you can enter new document dimensions. Try something like 400 wide and 500 high (which would give approximately the same aspect ratio as an 8 x 10 photo). You'll probably have to adjust your camera again afterwards. ok, I think that's the reason. I haven't tried to adjust that yet into a portrait. I work on a small laptop lol and I forget I have to adjust poser to widen the workspace. Do you know how to move the cameras in and out using the camera controls, zippy? These are the two I use most frequently after 'the ball', whatever it's called. Disregard if I misunderstood you ;) I do use that and mainly the dials. I think it's the size of my laptop monitor and my P4 work window being too small. lol. :) whacks myself upside my head. ty.
I might have to try and use the auxiliary camera cos I can't seem to adjust my doc window without it cutting off my dials. thanks guys, will play around with it some more. I've been struggling with this for 3 days lol. I'll delete the above image, it opened up too big. ;)
Message edited on: 02/16/2005 01:49
for this kind of shot, i agree with xantor, use the main or auxiliary camera. set focal length to a minimum of 80 (i use 100). with these cameras, you'll have more freedom of movement, like a real camera, than the dolly while the face camera will remain pointing at ... the face. BTW, i use the face camera primarily to "zoom in" for posing the head and setting up facial expressions, not rendering. :-)
Poser 4 has the same capability to render to a new window ... is this what you mean when you say you are opening a new doc window? yes, sorry bout that. It's just that I have to try to adjust it to fit my laptop screen. ok, thanks, will check it out. I put a render in my gallery, playing around with the doc sizes.
I'm tying to make her sit but not low to the ground, tried every which way to make her go up, so she's sitting in front of the camera. I would like to get the entire body in and not just a headshot. Is there a dial setting I can use for closeups? I've tried the different camera angles but the body is sitting. I'm in P4. ;) ty.
