Thu, Jan 30, 5:06 PM CST
Subject: UV mapping in vue5?
Max3DD3 ( ) posted Tue, 15 February 2005 at 3:17 PM ยท edited Thu, 30 January 2025 at 11:41 AM
Is this a feature of vue, can UV maps be imported? Many thanks Max
agiel ( ) posted Tue, 15 February 2005 at 4:08 PM
Not sure what you mean by 'imported'. You can use UV mapped objects in Vue 5 along with their bitmap textures if this is what you want to know.
Max3DD3 ( ) posted Tue, 15 February 2005 at 4:32 PM
well lets say i use UVmapper the program and map a texture to an object such as a decal will when i import the object into vue5 be kept as a decal?
agiel ( ) posted Tue, 15 February 2005 at 6:21 PM
It will :) ... I have done that once - mapped an object with UV mapper, texture it with Deep Paint and render it in Vue 4.
silverblade33 ( ) posted Tue, 15 February 2005 at 7:39 PM
it imports most standard file formats, including .obj And I know form stuff I've just done it imports textures I make with UV mapper just fine :) Only oddity Vue has though is it does Alpha maps in reverse, WHITE is transparent, not black, weird! But there's a button for inverting each texture (colour, bump, transparent/alpha) in the material editor so it's no problem :)
SAMS3D ( ) posted Wed, 16 February 2005 at 3:45 AM
Yes, you have to change your settings don't forget, the size of maps, so import your object, go to the material used, import map, then change size, x=1.000 and y=-1.000, have fun...Sharen
